POV-Ray : Newsgroups : povray.general : .pov and .ini differences Server Time
19 Nov 2025 03:55:50 EST (-0500)
  .pov and .ini differences (Message 1 to 4 of 4)
Subject: .pov and .ini differences
Date: 21 Nov 2011 17:05:00
Message: <web.4ecaca281e880ce723096ba30@news.povray.org>
I have a scene which renders well when I select to render the .pov file. I have
now created an .ini file to render the scene repositioning the camera using the
animation functionalities.
I am finding that when I render from the .ini file the scene is much darker. I
thought that the Display_Gamma and File_Gamma in the .ini file were causing that
but I tried removing all the lines from the .ini file (except Input_File_Name)
and the result is still much darker.
I am almost sure that I am doing something wrong with gamma correction. In the
scene, I am using "assumed_gamma 1" in the global_settings section and it is set
up for version 3.7. I am using radiosity and media.
I will appreciate any suggestion.
Thanks,
...JC
Subject: Re: .pov and .ini differences
Date: 21 Nov 2011 18:23:41
Message: <4ecadd7d$1@news.povray.org>
Am 21.11.2011 23:01, schrieb jcarlos:
That is very... strange.
Gamma correction is a good bet, though I have currently no idea what's
going on there.
What operating system are you using?
Are you usually rendering the .pov file from within the GUI? Are you
rendering from the .ini file from within the GUI as well?
Date: 22 Nov 2011 05:55:00
Message: <web.4ecb7ea8e415861b23096ba30@news.povray.org>
I need to beg your pardon.
While I was making a test scene to show you, I realized that my .pov and .ini
files were in different directories, i.e. the .ini was not opening the .pov that
I was modifying but an older one.
Sorry again and congratulations for the latest versions. The quality of the
images has been really improved, mainly for the radiosity which now really
cools.
...JC
Date: 23 Nov 2011 16:14:22
Message: <4ecd622e$1@news.povray.org>
> Hi,
> Thanks,
> ...JC
I'd check display_gamma and file_gamma.
If it's only display_gamma that is wrong, then you are OK as the
effective output should be correct.
If file_gamma is wrong, then your images will have incorrect gamma
information and will display incorectly.
A good bet would be to set both to sRGB as it should match most hardwares.
Keep assumed_gamma 1
