POV-Ray : Newsgroups : povray.general : Trying to translate an isosurface function Server Time
15 Jan 2026 10:54:51 EST (-0500)
  Trying to translate an isosurface function (Message 1 to 5 of 5)
Subject: Trying to translate an isosurface function
Date: 10 Nov 2011 20:35:01
Message: <web.4ebc7b038b30719f193ade1e0@news.povray.org>
trying to do is translate the result of a function on the isosurface in the x or
I can create a rippled surface for my isosurface using the following:
function {(y - cos(sqrt(x*x + z*z)*5*pi)*0.08}
I can get the same result if I construct the function using a pattern, using
something like:
#declare fn_ripples1 = function {
  pattern {ripples scale 0.1 translate <0.5, 0, 0.5>}
The advantage of the pattern is I can translate the result of the function
different surface to that generated by the function outside of the pattern.
#declare fn_myripples = function { // This doesn't work as expected
  pattern {
    function {cos(sqrt(x*x + z*z)*5*pi)*0.08}
obvious.
Any suggestion are welcome.
Cheers,
Alan
Subject: Re: Trying to translate an isosurface function
Date: 11 Nov 2011 02:57:10
Message: <4ebcd556$1@news.povray.org>
On 11-11-2011 2:31, Alan M wrote:
> obvious.
I think paragraph *2.3.3.3.9 Transformations on functions* of the docs
will help you.
Date: 11 Nov 2011 05:30:01
Message: <web.4ebcf87d259ed049193ade1e0@news.povray.org>
> > obvious.
> will help you.
> Thomas
Thanks, it does help and explains the approach very well. Bit embarrassed to get
an RTFM as I was reading this part of the docs before I posted the question -
should've kept reading.
Alan
Date: 11 Nov 2011 07:26:48
Message: <4ebd1488$1@news.povray.org>
Sooner or later we all sin against the RTFM law ;-)
Date: 13 Nov 2011 04:38:02
Message: <4ebf8ffa@news.povray.org>
pattern.
 >    pattern {
I believe patterns evaluate the function and then wrap the resulting
value to the range [0,1). Since cos() returns negative numbers
sometimes, they're getting wrapped around to higher values (for
instance, -.3 becomes .7).
  - Slime
