POV-Ray : Newsgroups : povray.general : Help on POV Raytracer malfunctioning Server Time
15 Jan 2026 10:54:52 EST (-0500)
  Help on POV Raytracer malfunctioning (Message 1 to 3 of 3)
Subject: Help on POV Raytracer malfunctioning
Date: 9 Nov 2011 09:45:01
Message: <web.4eba91a4ac93d8f6ab69b5980@news.povray.org>
I have been working with dialux software for a long time and I have frequently
used POV Raytracer without any problems.
However, recently, every time I try to use POV an error message appears (Editor
DLL initialization failed (LoadLibrary failed, code is 0000007e) and it is
unable to do the render image. This started after I downloaded the 64 bit
version from pov ray web site and installed it.
After this situation appeared for the first time, I have tried different
solutions:
-install again the 32 bit POV Raytracer version.
-uninstall Dialux and install it again.
-install POV in a different directory.
Unfortunately, none of this has solved the problem so I am asking for your help
in order to be able to use POV again.
Thank you.
Subject: Re: Help on POV Raytracer malfunctioning
Date: 9 Nov 2011 11:41:36
Message: <4ebaad40$1@news.povray.org>
Am 09.11.2011 15:43, schrieb AnaM:
> solutions:
As far as I know, Dialux comes with an adapted version of POV-Ray
(though I may be mistaken there). Have you tried installig Dialux again
with all other POV-Ray versions uninstalled?
Which version of POV-Ray did you try? 3.6.2? 3.7.RC3? or an earlier one?
Date: 9 Nov 2011 12:20:02
Message: <web.4ebab58f8b1c197eab69b5980@news.povray.org>
> > solutions:
Yes, I have tried several times to install Dialux whithout any other POV-Ray
I tried to install POV Ray 3.6.2 version.
