POV-Ray : Newsgroups : povray.general : Flatten n-dimension array? Server Time
29 Jul 2024 12:25:25 EDT (-0400)
  Flatten n-dimension array? (Message 1 to 3 of 3)
Subject: Flatten n-dimension array?
Date: 18 Oct 2011 09:00:01
Message: <web.4e9d76d82fef771f77e50e540@news.povray.org>
Is there a way in SDL to flatten an n-dimensional array?
Everything I've tried so far seems to require knowing the array size in advance
and accessing specifically: flat[foo] = array[x][y]
It looks like the only way to make a method which can take an array as input and
flatten it will need to have a switch statement in it to fork to appropriately
deep loops. I don't like that though.
Any other options?
Thanks,
Ian
Subject: Re: Flatten n-dimension array?
Date: 18 Oct 2011 10:22:31
Message: <4e9d8ba5@news.povray.org>
> Any other options?
  I'm too lazy to check now, but wouldn't dimension_size() return 0 for
dimensions higher than what the array is? (It could also cause an error,
in which case this couldn't be used.)
  A recursive macro can be created to do what you want (once you know the
dimensions of the array). It's not completely trivial to write, but shouldn't
be too difficult either.
Date: 18 Oct 2011 19:45:01
Message: <web.4e9e0ea59b1e54a277e50e540@news.povray.org>
The way I currently handle this is by using dimensions() to set the counter in a
for loop, which then measures each dimension individually [I assume oddly shaped
arrays] and utilizes this to produce a count of indices required in the 1D
array. This works based on my testing so far [not extensive].
That seems to be the generic solution I've seen implemented in languages similar
to SDL. I wanted something cleaner, but that may not be an option.
If the urge strikes you, feel free to take a stab at it along with me. :p
I'll put some more effort into this, but since it isn't really for anything I'm
doing specifically, other than making a .mcr file of array utilities typically
found in many C based languages, I may abandon it for things more interesting
and less time consuming. time == money ;)
I need to make some more context-selected pseudo overloads for higher
dimensions/etc.., but so far I have:
IndexOf() [Vector, non-vector]
Contains() [Vector, non-vector]
Shuffle() [Fisher-Yates, Bruteforce]
Resize()
CountDefined()
Just those few have made a *lot* of things I usually do much less tedious.
Ian
