POV-Ray : Newsgroups : povray.general : Can I not pass a file to a macro? Server Time
29 Jul 2024 14:19:09 EDT (-0400)
  Can I not pass a file to a macro? (Message 1 to 4 of 4)
Subject: Can I not pass a file to a macro?
Date: 5 Aug 2011 17:15:00
Message: <web.4e3c5c1e1d69a39a85de7b680@news.povray.org>
When I run:
______________________________________
#version 3.7;
#macro Write_something (N, FileID)
   #write (FileID, N)
#fopen F "test.txt" write
Write_something ("Hello, world.\n", F)
#fclose F
I get the error:
"C:\Users\Ricky Callwood\Documents\POV-Ray\test\file_param.pov" line 19: Parse
Error: Expected 2 parameters but only 1 found.
I am running POV-Ray version 3.7RC3.
My OS is the infinitely exasperating Windows 7 Ultimate.
Subject: Re: Can I not pass a file to a macro?
Date: 5 Aug 2011 19:50:00
Message: <web.4e3c80943ab75a423ab9fa310@news.povray.org>
> When I run:
> #version 3.7;
>    #write (FileID, N)
> #end
> #fclose F
I dunno why, but I cant pass either the fileid as parameter
 #version 3.7;
  #macro Write_something (N)
    #write (f,concat(N))
#fopen f "test.txt" write
 Write_something ("Hello, world.\n")
I hope to serve this at the moment, removing the fileid parameter
B. Gimeno
Date: 5 Aug 2011 20:05:00
Message: <web.4e3c85083ab75a423ab9fa310@news.povray.org>
A variation in which you can enter the output filename as a paremeter.
 #macro Write_something (file_name,N)
    #fopen F file_name write
    #write (F,N)
    #fclose F
 Write_something ("test.txt","Hello, world.\n")
By the way, is there a powerful and unavoidable reason to introduce as a
parameter the id_file handler?
Regards
B. Gimeno
Date: 5 Aug 2011 20:55:00
Message: <web.4e3c909e3ab75a4285de7b680@news.povray.org>
Yes.  If the macro is called more than once.
I found a workaround, though.
#macro Write_something (Filename, N)
   #fopen F Filename append
   #write (F, N)
   #fclose F
#declare FILE1 = "test.txt"
#fopen F FILE1 write #fclose F //zero the output file
Write_something (FILE1, "Hello,\n")
Write_something (FILE1, "world.\n")
