POV-Ray : Newsgroups : povray.general : Is there a way to set the minimum render distance Server Time
10 Apr 2026 21:43:21 EDT (-0400)
  Is there a way to set the minimum render distance (Message 1 to 2 of 2)
Subject: Is there a way to set the minimum render distance
Date: 1 Jul 2011 07:10:00
Message: <web.4e0daa18321a595fcf4366b60@news.povray.org>
I want to images that slice through my object. I figure that the easiest way to
do this is to vary the minimum distance at which a surface is rendered. Is there
a way to do this in POV-Ray?
Subject: Re: Is there a way to set the minimum render distance
Date: 1 Jul 2011 07:50:00
Message: <web.4e0db3d24aeae2aa85627c70@news.povray.org>
"Andy" <nomail@nomail> wrote:
> Hi,
I'm not sure about the minimum rendering distance, but a fairly easy way of
getting a cross-sectional view is to create an *intersection* of your object and
a *box* than encloses the part you want to view.
Also, it occurs to me that if you rendered only the portion of an object a given
distance from the camera, the resulting surface would be curved (spherical).
If, for some reason, that is what you wanted, you could just create the
*difference* of your object and a sphere centered at the camera location.
I hope this helps.
Best Regards,
Mike C.
