POV-Ray : Newsgroups : povray.general : Tapering helix Server Time
30 Sep 2024 12:12:45 EDT (-0400)
  Tapering helix (Message 1 to 6 of 6)
Subject: Tapering helix
Date: 21 Jun 2011 17:10:00
Message: <web.4e010808b9860283662ad7fb0@news.povray.org>
I'd like to create a building shaped like a helix that tapers toward the top.
Can anyone come up with a good method? The helix macros in shapesq don't produce
the results I expect and they're not solid as far as I can tell.
Mike
Subject: Re: Tapering helix
Date: 22 Jun 2011 13:42:57
Message: <4e0229a1$1@news.povray.org>
Le 21/06/2011 23:07, posfan12 nous fit lire :
Do you mean a spiral along a cone ?
Or a rotating square/whatever which get smaller on the top (dimension of
side is reducing like the radius of the cone) ?
(center of the square match the axis of the cone)
you can try rotating a slice while increasing the angle and decreasing
the size.
// untested, 3.6/3.7
union {
#local Side=10;
#local Max_Height=20;
#local Step=0.1;
#local Current=0;
#local Turn=60; /* Degrees of rotation per vertical unit */
#while (Current < Max_Height)
#local AA=<Side * (Max_Height - Current)/Max_Height, Current, Side *
(Max_Height - Current)/Max_Height>;
#local BB=<Side * (Max_Height - Current)/Max_Height, Current+Step, Side
* (Max_Height - Current)/Max_Height>;
box { AA*<-1,1,1>,BB rotate Turn*Current*y }
#local Current=Current+Step;
Date: 22 Jun 2011 22:11:30
Message: <4e02a0d2$1@news.povray.org>
I looked for an image on Google, and this is the closest I found.
http://www.constructionphotography.com/ImageThumbs/A162-01067/3/A162-01067_Spiral_staircase_in_office_building.jpg
I want a shape like that, except tapering to a point toward the top. The
storeys should each remain the same height though.
Mike
Date: 23 Jun 2011 13:34:40
Message: <4e037930@news.povray.org>
> the size.
> union {
> #local Side=10;
> #local Step=0.1;
> #local Current=0;
> #while (Current<  Max_Height)
> #end
also works using sphere instead of box ... just called sphere with AA.x,BB.x
a little play with some of the parameters and it makes a cool shape
(posted in images) :-)
Date: 25 Jun 2011 19:13:12
Message: <4e066b88@news.povray.org>
There are a number of ways to achieve your goal.
1) Make a #while loop of objects to produce a helical shape
2) Make a helical mesh (most difficult)
3) Use a helical isosurfaces (easiest)
Number 3 is pretty easy, but will be the slowest to render. Of course
you must know just what /kind/ of tapered helix you want.
Example 1: Helix with density change along y-axis
#include "functions.inc"
#declare DensityChange = 0.25; // rate of density change
isosurface{
   function{
     f_helix1(
       x,y,z,
       1,  // P0: number of helices
       6, // P1: period (number of turns)
       0.25,   // P2: minor radius
       0.75,  // P3: major radius
       1.0, // P4: shape parameter
       1,  // P5: cross section
       0.0// P6: cross section rotation angle
     )+y*DensityChange
   accuracy .001
   max_gradient 1.494 /* found by looking at the message pane */
   contained_by{ box{<-2,-4,-2>,<2,3.9,2>} }
   pigment{rgb 1}
Example 2: Helix with scale change along y-axis (probably the one you
wanted)
#declare TaperAmount = 0.5; // amount of y-axis tapering
isosurface{
   function{
     f_helix1(
       x/(TaperAmount*4-(y+4)*TaperAmount),
       (y+4)/(TaperAmount*4-(y+4)*TaperAmount)-4,
       z/(TaperAmount*4-(y+4)*TaperAmount),
       2, // P1: period (number of turns)
       0.50,   // P2: minor radius
   accuracy .001
   max_gradient 100 /* could be much higher, could be much slower to
render */
   contained_by{ box{<-2,-4,-2>,<2,-.1,2>} }
   pigment{rgb 1}
You should check out the isosurface tutorials available. Isosurfaces are
easy to learn how to use. If you are somewhat dedicated, know or want to
learn just how math interfaces with geometry, and have the time, then
isosurfaces are definitely worth the effort :)
~Sam
Date: 26 Jun 2011 11:44:39
Message: <4e0753e7$1@news.povray.org>
>> the top.
>> don't produce
I had thought of using a mesh. However I was hoping there were something
that was easy *and* fast. #1 seems like it's kind of in the middle.
Mike
