POV-Ray : Newsgroups : povray.general : pov 3.7: getting in-progress render preview? Server Time
26 Feb 2026 04:42:42 EST (-0500)
  pov 3.7: getting in-progress render preview? (Message 1 to 5 of 5)
Subject: pov 3.7: getting in-progress render preview?
Date: 24 Apr 2011 18:15:00
Message: <web.4db49fcc69ad9535b98d3ceb0@news.povray.org>
Hi everybody
and its pov render script) to get partial rendered pictures, to give the user
For example, would it be possible for pov ray to periodically write what has
already been rendered in the output file, instead of only creating and writing
Cheers,
Bastien
Subject: Re: pov 3.7: getting in-progress render preview?
Date: 25 Apr 2011 02:36:28
Message: <4db5166c$1@news.povray.org>
Le 25/04/2011 00:11, mont29 nous fit lire :
> Hi everybody
> (I hope I’m in the good thread…)
> So, I’d like to know if there is a way for an external program (here, Blender
> something else than a black screen during whole render ?
> this one once render is completed ?
The image format (whatever could it be with +F...) in 3.7 is generated
only at the very end of the rendering process.
Nevertheless, if you use the intermediate file storage (which slow down
the render process if it is quick), which is used for big resolution (as
it is triggered by default for 128 MB of raw buffer)
( see http://wiki.povray.org/content/Documentation:Reference_Section_1
+MI option), you could get some data. I guess I would have to document
that file (fixing it forever... )
You could instead use a +D switch to open a preview window. That's
assume of course that the DISPLAY setting of X11 has been set for the
relevant systems (unix-like).
Date: 25 Apr 2011 04:30:00
Message: <web.4db52ecc1f1eca7cb98d3ceb0@news.povray.org>
format (like png, tga, etc.)? Anyway, a 800*600 is about 1.5Mb (or 2Mb with
Anyway, thanks very much for your answers :)
Date: 25 Apr 2011 05:45:22
Message: <4db542b2$1@news.povray.org>
Le 25/04/2011 10:20, mont29 nous fit lire :
> Thanks for confirming that…
> I have seen this option, and tried to use it, but I couldn’t figure out where
> that intermediary file is stored… And I suppose it does not use a standard
> alpha), and the minimum buffer size is 1Mb, so it wouldn’t be that much useful.
800 x 600 is about 9 megabytes of storage in raw.
(5 COLC (== float) per pixel, with 32 bits per float, usually)
At the very end of the file there is 3 extra size_type, which hold : the
size of the pixel_type, the width of the picture, the height of the
picture (in that order).
Once created, the file keep its size.
Position in the file of pixel (x,y) is (y * witdth + x)*size_of_pixel_type
A gap can exist between the last pixel and the 3 size_type at the end.
pixel_type is an array of 5 COLC.
(order is Red, Green, Blue, Filter, Transmit)
The file is a temporary file, usually in the local directory unless you
tuned it otherwise. (on unix : it's /tmp/pov$$ with $$ the process id)
Date: 25 Apr 2011 11:40:00
Message: <web.4db594e91f1eca7c7843e3c10@news.povray.org>
