![](/i/fill.gif) |
Hi, guys,
Nowadays I am consentrating on simulating a scene of rain animation. My idea for
this simulation is to utilize Particle System for move the raindrops in 3D space
by time. Each raindrop is represented by a particle with proporties such as
mass, velocity, position, lifespan, etc. This drop particle can describe the
exact motion of the drop, however, it can't turn up a realistical rain trace in
the air. That is because the human can see a rain line for the reason of vision
remaining. Therefore I want to take advantange of series of rain textures for a
realistical rendering. Then we should define 4 verticies arond the drop
particle itself according to drop's position and moving direction. Supporting
these textures above have been known and 4 vertecies of per drop can be
calculated at any time.
Then, how to render this rain scene according to presetn idea? Has anybody seen
the example codes yet similar with this idea? Or can anybody give me some
constructive advices?
Thank you very much.
email: dre### [at] 163 com
![](/i/fill.gif) |
![](/i/fill.gif) |
Dream wrote:
> Supporting these textures above have been known and 4 vertecies of
> per drop can be calculated at any time.
sounds reasonable although I'm not sure how well it works
to make convincing rain.
Instead of using object copies you could also
1. Use MegaPOV and try it's motion blur feature, or
2. Render the animation at a higher frame rate, and
then average subframes together.
![](/i/fill.gif) |
