POV-Ray : Newsgroups : povray.general : Help with function Server Time
19 Nov 2025 07:07:06 EST (-0500)
  Help with function (Message 1 to 6 of 6)
Subject: Help with function
Date: 31 Mar 2011 04:20:01
Message: <web.4d943844cb1d54df9c4fb0ad0@news.povray.org>
can someone help me with the following transform:
#local s = 1 / (2 * (1 + sum(k,1,n, cos(2*pi*k/n)) ));
pov throws a nutty and says i don't have a semi-colon and I know i do.
the code is below.
Any help is appreciated.
A.D.B.
#include "kolors.inc"
#include "math.inc"
light_source { <0.0, 0.0, -20.0> 1.0 }
     perspective
     location <0.0, 0.0, -20.0>
     up y
     right (image_width/image_height)*x
     look_at 0.0
#default { pigment { White } finish { ambient 0.3 diffuse 0.6 } }
#macro nGon(n, r)
     prism {
          -0.0625, 0.0625, 2*n+1
          #local i = 0;
          #while(i <= 2*n)
               #if(i <= n)
                    r*<cosd( i * (360/n) ), sind( i * (360/n) )>
               #else
                    (r-0.015625) * <cosd( i * (360/n) ), sind( i * (360/n) )>
          #local i = i + 1;
               rotate -90.0*x
#macro sierpinski(n, r, E, T)
#local s = 1 / (2 * ( 1 + sum(k,1,n/4,cos(2*pi*k/n)) ));
object {
     union {
     union {
     #if(r >= E)
          #local i = 0;
          #while(i < n)
#local T1 = (1 - s ) * r * <cos(2*pi*(i+1)/n), sin(2*pi*(i+1)/n), 0>;
               sierpinski(n, r*s, E
                    transform { translate T1 })
          #local i = i + 1;
     nGon(n, r)
          transform { T }
sierpinski(6, 5, 1/32, transform { translate 0*x })
Subject: Re: Help with function
Date: 31 Mar 2011 08:15:29
Message: <4d947061$1@news.povray.org>
Just a casual glance so I might be wrong, but I think you're misusing
the sum function
Date: 31 Mar 2011 10:45:01
Message: <web.4d9492df2c67487c86ff1d480@news.povray.org>
> the sum function
Yep, try something like this, with a function wrapper for sum:
#local fn = function(k,n) { sum(k,1,n, cos(2*pi*k/n)) }
#local s = 1 / (2 * (1 + fn(1,2)));
www.McGregorFineArt.com
Date: 31 Mar 2011 11:30:00
Message: <web.4d949cda2c67487c81c811d20@news.povray.org>
> > the sum function
Though the docs don't seem to say so explicitly, it appears that the sum() and
prod() functions need to be in a function.
You actually don't need to pass the 'k' component in Robert's example:
#local fn = function(n){sum(k,1,n/4,cos(2*pi*k/n))}
Better yet, include the whole thing inside the function:
#local fn = function(n){1/(2*(1+sum(k,1,n/4,cos(2*pi*k/n))))}
Then you only need to call fn(n) in place of #declaring s.
Also note, declare this before your macro.  As the macro gets called more than
once, it will try to redefine fn() and give you an error unless you #undef it
each time, but this is unecessary if you keep it outside the macro.
-tgq
Date: 31 Mar 2011 14:35:01
Message: <web.4d94c8ce2c67487cd7f39bd00@news.povray.org>
> > > the sum function
> -tgq
ok, it works, mostly.  I just added an ifndef around the transform declaration.
I also replaced the nGon() macro call with a simple sphere{ 0.0, 0.03125 }
only one thing:  I would expect to get a mengher sponge at n=4, but all I get is
a white grid.
A.D.B.
Date: 31 Mar 2011 15:33:23
Message: <4d94d703$1@news.povray.org>
>>> the sum function
Yep ... when I had a quick look at the docs the example does appear to
be eluding to that point, but yes it's a bit thin, and that's why I
wasn't 100% on my initial advice.
I've been asked to capture some information from the "Light Attenuation"
thread in this same news group and see if I can glean something from
that discussion and get it into the docs ... I'll add prod/sum to my to
do list as well.
Jim
