POV-Ray : Newsgroups : povray.general : Math error Server Time
17 Mar 2026 19:52:14 EDT (-0400)
  Math error (Message 1 to 4 of 4)
Subject: Math error
Date: 18 Sep 2010 02:05:01
Message: <web.4c945599cfc6a233507e8a090@news.povray.org>
I'm having trouble with a parameterized calculation in three forms
((T*P)/2)*pow((clock - index(Start))/index(Duration),2)
(P*T*T)*pow((clock - index(Start))/index(Duration),2)
and
T*P*( (clock - index(Start)) / index(Duration) )
index(T) is calculated by a macro which takes a 3d vector T
_TICK_ is defined in another macro.
#macro index(T)
     #local Seconds = T.x*3600 + T.y*60 * T.z;
     _TICK_*Seconds     // where _TICK_ is (final_clock - initial_clock) /
animLen
I passed various elements of the calculation to a debug statement, and the
problem seems to arise in the (clock - index(I))/index(D) portion, the result
being that my Delta_T is about 10,000 times larger than it should be.
which shouldn't work
When I run the same calculation with set values as below
(5*1080/2)*pow((clock - 0)/index(5),2)
I get exactly what I should get, as confirmed by my pocket calculator with
various different values.
I have three files illustrating this problem in a zip file I'll upload to p.b.a
test.pov illustrates the solution that works while test3.pov illustrates the
problem
I've been rendering with the following command line:
+a0.03 +ki0.0 +kf1.0 +kfi1 +kff600 -D -GA
and encoding with mencoder at 60fps
any insight on this problem would be appreciated
Subject: Re: Math error
Date: 18 Sep 2010 02:23:12
Message: <4c945ad0$1@news.povray.org>
	Shouldn't that be a "+" before "T.z"?
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 18 Sep 2010 13:15:00
Message: <web.4c94f2ae50cc844d507e8a090@news.povray.org>
>   Jerome
It's correct in the files.  Just a typo in the post.
A.D.B.
Date: 23 Sep 2010 00:10:01
Message: <web.4c9ad1be50cc844d507e8a090@news.povray.org>
> >   Jerome
> A.D.B.
It seems that the problem lay in the fact that the operations aren't precomputed
by the separate macros but, rather, dropped in to form a larger equation. The
result is that I had to parenthesize EVERYTHING in each macro, so that the
proper order of operations could be preserved.
It makes sense when I think about it.
the troublemaker line was in the eClock macro
_TICK_*Seconds
i changed it to (_TICK_*Seconds) and voila!
I also put encapsulating parentheses around each of the three formulae in Timer.
The Timer macro is now self-limiting and additive so that the line:
rotate (Timer(1, <0, 0, 0>, <0, 0, 5>, 1080) +
        Timer (3, <0, 0, 5>, <0, 0, 10>, 1080))*x
creates a timeline for rotation about the x axis where the first five seconds
are spent accelerating to 4 revs/sec and the last five are spent rotating at a
constant 4 revs/sec.
Comments?
A.D.B.
