POV-Ray : Newsgroups : povray.general : needed normal perturbation fix Server Time
28 Jan 2026 09:30:35 EST (-0500)
  needed normal perturbation fix (Message 1 to 7 of 7)
Subject: needed normal perturbation fix
Date: 9 Jun 2010 13:35:00
Message: <web.4c0fcf7f8bc1bf94ad2b88370@news.povray.org>
A new technical paper has just been uploaded which shows
that an initial projection of the gradient is needed to do proper normal
perturbation of height functions.
http://jbit.net/~sparky/sfgrad_bump/
Most of the paper is aimed at rendering on GPUs but an equation (eq. 4) is
presented which produces Blinn's perturbed normal but in a unified (2D/3D bump
function) formulation.
Section 5 gives more details regading differences though the analysis is given
in section 3.
The point is that simply adding or subtracting the 3D gradient of the function
gives visual errors and is not equivalent to the normal of the displaced
function nor a good approximation. Since it is an easy fix I would recommend
that it is worked into povray.
Cheers!
Subject: Re: needed normal perturbation fix
Date: 9 Jun 2010 16:48:06
Message: <4c0ffe06$1@news.povray.org>
Le 09/06/2010 19:31, sparky nous fit lire :
> in section 3.
You are of course aware that it cannot be a fix: existing scenes might
rely on actual behaviour and the Guardians of the Temple will not allow...
If it is easy, you might suggest the code correction (on beta code ?).
The paper looks like scholar... but fails to have an abstract, explicit
demonstration and rely a lot on asserting evidences (without formal
demonstration/mesurement/estimation).
Date: 9 Jun 2010 17:15:00
Message: <web.4c10040f9f797603ad2b88370@news.povray.org>
It's very easy.
The paper gives a mathematical derivation for the formulation.
Furthermore, omiting the initial projection of the gradient before subtraction
(from the original normal) is not only theoretically wrong but as shown in
figure 2 also visually wrong.
Date: 9 Jun 2010 17:16:16
Message: <4c1004a0$1@news.povray.org>
Am 09.06.2010 22:48, schrieb Le_Forgeron:
I'm not sure about normal pertubations in general, but bump maps need an
overhaul anyway. (Not a top priority thing though.)
Date: 10 Jun 2010 11:45:37
Message: <4c1108a1$1@news.povray.org>
Le 09/06/2010 23:13, sparky nous fit lire :
> It's very easy.
Good & Great, awaiting pieces of code.
It always remind me of the last conjecture/theorem of Pierre de Fermat.
The Travelling Salesman Problem is very easy too, but the margin is a
bit too small to show it.
Date: 11 Jun 2010 03:49:48
Message: <4c11ea9c@news.povray.org>
"Le_Forgeron" <jgr### [at] freefr> schreef in bericht
news:4c1108a1$1@news.povray.org...
LOL! Fantastic! You made my day.
Date: 11 Jun 2010 13:20:01
Message: <web.4c126f339f797603ad2b88370@news.povray.org>
The code is given in listing 2.
