POV-Ray : Newsgroups : povray.general : Is a circular gradient possible? Server Time
10 Jan 2025 12:49:09 EST (-0500)
  Is a circular gradient possible? (Message 1 to 4 of 4)
Subject: Is a circular gradient possible?
Date: 14 May 2010 11:15:00
Message: <web.4bed6873360dbc1e70fdf2650@news.povray.org>
I need an image of a simple circle with a color gradient from the perimeter to
the center. Can that be drawn in povray? I've tested gradient but that only goes
in one direction.
thanks
Subject: Re: Is a circular gradient possible?
Date: 14 May 2010 11:40:13
Message: <4bed6edd$1@news.povray.org>
Am 14.05.2010 17:12, schrieb wilhelm:
> in one direction.
try the "spherical", "cylindrical", "onion" or "wood" patterns.
Date: 14 May 2010 13:34:22
Message: <4bed899d@news.povray.org>
> > in one direction.
  And if none of those meets your exact needs, you can always write your
own pattern function (by writing a user-defined function and using it as
a pattern).
Date: 14 May 2010 18:43:03
Message: <4bedd1f7@news.povray.org>
>> perimeter to
>> only goes
>> in one direction.
NON-repeating patterns:
spherical goes from 1 at the origin and drop to zero at a spherical
radius of 1 and stay at that value.
Cylindrical evaluate to 1 on the y axis and drop to zero at a radius of 1.
Repeating patterns:
onion start at zero at the origin, goes to 1 at radius 1, then drop back
to 0. It can be seen as a spherical gradient. onion use a ramp_wave.
wood evaluate to zero along the z axis. You can look at it as a
cylindrical gradient pattern. wood use a triangle_wave.
Try those alone:
plane{-z,0 pigment{wood color_map{[0 rgb 0][1 rgb 1]}ramp_wave}
finish{ambient 1}translate 5*z}
plane{-z,0 pigment{onion } finish{ambient 1}translate 5*z}
Both of those render identicay.
