POV-Ray : Newsgroups : povray.general : Colors of the rainbow Server Time
12 Oct 2025 00:39:09 EDT (-0400)
  Colors of the rainbow (Message 1 to 7 of 7)
Subject: Colors of the rainbow
Date: 12 Apr 2010 21:00:00
Message: <web.4bc3c1f5568629a3d9ac4bb10@news.povray.org>
Hello,
I'm trying to produce the colors of the rainbow inside a #while loop, but to no
avail so far. I need them to progress from red to violet, and I am using the
CHSV2RGB for the conversion, which I thought would make things easier. Still,
all I get is a constant red color in my blob.
Here is the code. The problem is in the blob with the loop (which produces an
ascending spiral):
camera{
 location < 0, 150, -1000 >
 look_at < 0, 20, 0.000 >
 angle 5.000
light_source{ <800,4000, 700> rgb 1 }
sphere {
  <0, 0, 0>, 1
     gradient y
     color_map {
       [0.0 color rgb < 01.0, 01.0, 1.0 >]
   finish { diffuse 0 ambient 1 }
  hollow on
  no_shadow
  scale 30000
blob {
    threshold .0005
    #declare Cr = 0;
    #declare Mx = 2330;
    #declare Rd = 0.1;
    #declare Ap = 1;
    #declare As = 1;
    #declare Vl = 1;
    #while (Cr <= Mx)
        sphere { <0,0,0>, 1.3 ,1
                 translate <Cr*Ap*Rd*Rd,Cr*Vl*Rd*Rd*1.3, Cr*As*Rd*Rd>
                 rotate y*Cr*Vl
                         pigment{rgbft CHSV2RGB(<((Mx-Cr)/Mx), 1.0, 1.0>)}
        #declare Cr = Cr + 1;
___________
My intention here is to produce an ascending spiral with seven turns; each turn
being of a color of the rainbow (or something close to that). The spiral ascends
alright, but the colors don't vary at all.
There's very little documentation on CHSV2RGB, and I found no examples of it in
action, so any help will be greatly appreciated.
Ruy (an extremely absent POVer since 1994, version 2.2)
Subject: Re: Colors of the rainbow
Date: 12 Apr 2010 22:21:10
Message: <4bc3d516$1@news.povray.org>
> Hello,
The hue is given in degree. In your sample, it goes from 0 degree to 1
degree, giving an almost imperceptible change in coloration.
Change your code to:
#local Hue = (Mx-Cr)/Mx*360;
// Scale to a full circle on the colour wheel
// Adjust if you want to use a smaller or larger range
          pigment{rgb CHSV2RGB(<Hue, 1.0, 1.0>)}
OR change your pigment to:
pigment{rgb CHSV2RGB(<((Mx-Cr)/Mx)*360, 1.0, 1.0>)}
Date: 13 Apr 2010 04:35:01
Message: <web.4bc42c08db1f0f0260ff6bf40@news.povray.org>
Ah, so Hue varies from 0 to 360 degrees while Saturation and Value vary from 0
to 1. That's a very interesting piece of information. Exactly what I needed to
hear, Alain, merci!
It worked perfectly.
Ruy
> texture {
> Alain
Date: 13 Apr 2010 11:07:19
Message: <4bc488a7$1@news.povray.org>
> hear, Alain, merci!
> Ruy
>> texture {
>> Alain
To find that, you need to look inside colors.inc.
CHSV2RGB internaly calls CH2RGB.
CH2RGB is defined as:
#macro CH2RGB (H)
    #local H = mod(H, 360);
    #local H = (H < 0 ? H+360 : H);
    #switch (H)
       #range (0, 120)
          #local R = (120-  H) / 60;
          #local G = (  H-  0) / 60;
          #local B = 0;
       #break
       #range (120, 240)
          #local R = 0;
          #local G = (240-  H) / 60;
          #local B = (  H-120) / 60;
       #break
       #range (240, 360)
          #local R = (  H-240) / 60;
          #local G = 0;
          #local B = (360-  H) / 60;
       #break
    <min(R,1), min(G,1), min(B,1)>
When you look at that code, it becomes obvious that you are using
degrees. CHSL2RGB() also use degrees.
It should be added to the documentation.
Date: 13 Apr 2010 13:31:37
Message: <4bc4aa79$1@news.povray.org>
Done ...
http://wiki.povray.org/content/Documentation:Reference_Section_7#Color_macros
Jim
Date: 14 Apr 2010 06:10:52
Message: <4bc594ac@news.povray.org>
Definitely OOC but welcome back.
You have been assimilated, resistance was futile :-)
John
Cogito sum,|| wbu### [at] tznvypbz (rot'ed) || GPG Key Fingerprint:
ergo sum,  ||   These opinions are mine alone,   || 0D9BCF4CF1B71CA2F5F7
cogito     ||     others can find their own      || BFBBCBC34EDEAEFCE453
Date: 14 Apr 2010 14:00:00
Message: <web.4bc60265db1f0f021ad2eb90@news.povray.org>
> Done ...
> Jim
Excellent, thank you very much!
> John
Thanks! It's good to be back, even if just for a short while. :D
Ruy
