POV-Ray : Newsgroups : povray.general : How to generate radiosity data and then quit? Server Time
19 Nov 2025 17:39:27 EST (-0500)
  How to generate radiosity data and then quit? (Message 1 to 4 of 4)
Subject: How to generate radiosity data and then quit?
Date: 23 Mar 2010 21:25:01
Message: <web.4ba968f0a83ab146ab8b233e0@news.povray.org>
The power went out while my computer was in the middle of a long render. All is
not lost, since I've been meaning to try out rendering on multiple computers.
Eventually I'd like this all to be automated. So how do I get Pov to exit once
it finishes generating radiosity data?
Subject: Re: How to generate radiosity data and then quit?
Date: 23 Mar 2010 22:10:08
Message: <4ba97480$1@news.povray.org>
No way - POV-Ray won't let you go without a main render. You can use a
reduced resolution though, running this pre-render with "always_sample
on", effectively using it as just another pretrace pass.
Date: 23 Mar 2010 23:15:01
Message: <web.4ba9836ba74cfb2dab8b233e0@news.povray.org>
Does focal blur affect the radiosity data? My guess would be no. And how much
smaller is an acceptable resolution to generate radiosity data for the main
render?
Date: 24 Mar 2010 08:44:23
Message: <4baa0927$1@news.povray.org>
> render?
In some sense focal blur does affect radiosity data: You potentially get
a better sample coverage, because more rays are shot - and from slightly
different origins. So as a result, this may force POV-Ray to take
samples at places that would be missed otherwise. Other than that, there
is no effect on radiosity.
Thinking of the "main pre-render" as an additional pretrace step, I'd
suggest a resolution of (roughly) 2/pretrace_end in whatever dimension
is larger; the other dimension should be chosen according to the
intended aspect ratio of the main render. This way, you indeed mimick an
additional pretrace step (so you may choose a larger pretrace_end in the
first place).
