POV-Ray : Newsgroups : povray.general : "square" cylinder Server Time
10 Jan 2025 19:45:47 EST (-0500)
  "square" cylinder (Message 1 to 3 of 3)
Subject: "square" cylinder
Date: 7 Dec 2009 15:20:01
Message: <web.4b1d62c6195d7b0094e9b2120@news.povray.org>
Hi all,
I am running into a problem, I was wondering if POV-Ray had a command similar to
cylinder, but rather than making rounded edges, the edges were at 90 degree
angles. And the Radius would be the distance from the center of the square to
the closest corner?
Chris
Subject: Re: "square" cylinder
Date: 7 Dec 2009 16:53:56
Message: <4b1d7974$1@news.povray.org>
Le 07/12/2009 21:17, Chris nous fit lire :
> Hi all,
> the closest corner?
Nope.
But you can probably make a macro for that using box.
Now, you might need an additional number: the rotation along the axis
#macro Chris_cylinder(a,b,r,o)
//assuming b != a
#local leng=vlength(b-a);
#local wid=r/sqrt(2);
 <0,-wid,-wid>,<leng,wid,wid> rotate o*x
rotate vaxis_rotate(x,vcross(x,b-a),vdot(x,vnormalize(b-a)))
translate a
box { Chris_cylinder(<5,10,20>,<4,6,5>,0.6,45) ... }
Now, if it would be a built-in object, the number of sides could be also
an interesting option (yours defaults to 4!)
Date: 21 Dec 2009 12:50:00
Message: <web.4b2fb4b9db6cdf0e279899c60@news.povray.org>
Do you mean something other than superellipsoids or the Rounded Box macros?
