POV-Ray : Newsgroups : povray.general : x-ray like texture Server Time
19 Nov 2025 22:54:36 EST (-0500)
  x-ray like texture (Message 1 to 6 of 6)
Subject: x-ray like texture
Date: 13 Oct 2009 17:10:01
Message: <web.4ad4eb84e35696266e6d7c00@news.povray.org>
has anyone an idea how I can make such a fancy glowing faked "x-ray"-texture
with Pov-ray?
I mean those one can sometimes see on 3D anatomical illustrations, like e.g.
here:
http://www.istockphoto.com/stock-photo-6226515-x-ray-skull.php
http://www.istockphoto.com/stock-photo-9543726-skull-roentgen-4-view.php
Thanks,
Simone
Subject: Re: x-ray like texture
Date: 13 Oct 2009 17:37:58
Message: <4ad4f336$1@news.povray.org>
mone wrote:
> Hi,
> with Pov-ray?
> here:
MegaPOV has an angle of incidence pattern which creates this effect
quite nicely. A color_map where the faces pointing towards the camera
are transparent, and the angles facing to the side are opaque, will do
the job.
You can also do this with the official version of POV, with the "slope"
pattern. The results will not be accurate, however, unless you use an
orthographic camera.
Sam
Date: 13 Oct 2009 17:42:15
Message: <4ad4f437$1@news.povray.org>
> with Pov-ray?
There was talk about doing electron microscope images a while back.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.42ee8574fa1babc58072d1170@news.povray.org%3E
Someone else once talked about using a light with a negative intensity to
project blackness onto an otherwise-white surface or some such, which might
also do the trick.
Date: 13 Oct 2009 18:58:13
Message: <4ad50605@news.povray.org>
"stbenge" <not### [at] hotmailcom> wrote in message
news:4ad4f336$1@news.povray.org...
> mone wrote:
>> Hi,
>> "x-ray"-texture
>> with Pov-ray?
>> e.g.
>> here:
> MegaPOV has an angle of incidence pattern which creates this effect quite
> nicely. A color_map where the faces pointing towards the camera are
> transparent, and the angles facing to the side are opaque, will do the
> job.
> Sam
In case the slope pattern seems interesting to you I've posted an example on
povray.binaries.images. See:
http://news.povray.org/povray.binaries.images/thread/%3C4ad50483%40news.povray.org%3E/
Chris B.
Date: 13 Oct 2009 20:35:00
Message: <web.4ad51beee94f75c166e6d7c00@news.povray.org>
> the job.
Thanks! I will check it out if I understand it.
OK. I think I will try slope pattern first.
Have a nice day,
Simone
Date: 13 Oct 2009 20:45:00
Message: <web.4ad51e71e94f75c166e6d7c00@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> > with Pov-ray?
> also do the trick.
Yes, I found some examples via the link you posted above (I couldn't see the
link at first, but now when replying, it's visible.) There's also an example for
this complicated aoi thing in Megapov.
Light with negative intensity sounds logical, because it looks a bit like a
negative image in photography.
Thanks for your help!
Best wishes
Simone
