POV-Ray : Newsgroups : povray.general : Cannot run POV-Ray from Windows batch scripts Server Time
10 Jan 2026 19:46:24 EST (-0500)
  Cannot run POV-Ray from Windows batch scripts (Message 1 to 5 of 5)
Subject: Cannot run POV-Ray from Windows batch scripts
Date: 21 Jun 2009 00:40:01
Message: <web.4a3db92ce7e441a578641e0c0@news.povray.org>
I have recently upgraded POV-Ray for Windows from 3.6.1 to 3.6.2 (32-bit
edition).  Batch scripts that worked perfectly fine in the past now give me
this error message:
   Commandline processing error
   Only /EDIT and /RENDER may be passed to previous instance
Here is a sample script:
________________________________________________________________
: Options | Keep Single Instance must be OFF.
setlocal
set PATH=%PATH%;"C:\Program Files\POV-Ray for Windows v3.6\bin"
time /t
start /w pvengine /nr /exit +a +r3 -j +igamma +ogamma10 display_gamma=1.0
start /w pvengine /nr /exit +a +r3 -j +igamma +ogamma14 display_gamma=1.4
start /w pvengine /nr /exit +a +r3 -j +igamma +ogamma16 display_gamma=1.6
start /w pvengine /nr /exit +a +r3 -j +igamma +ogamma18 display_gamma=1.8
start /w pvengine /nr /exit +a +r3 -j +igamma +ogamma20 display_gamma=2.0
start /w pvengine /nr /exit +a +r3 -j +igamma +ogamma22 display_gamma=2.2
start /w pvengine /nr /exit +a +r3 -j +igamma +ogamma24 display_gamma=2.4
start /w pvengine /nr /exit +a +r3 -j +igamma +ogamma26 display_gamma=2.6
start /w pvengine /nr /exit +a +r3 -j +igamma +ogamma30 display_gamma=3.0
time /t
pause
endlocal
I tried the following variations and got the same error:
   start /w pvengine /nr /exit /render gamma.pov +a +r3 -j +ogamma10
      display_gamma=1.0
   start /w pvengine /nr /exit /render gamma.pov +igamma +a +r3 -j
Am I missing something?
I'm running Windows XP Media Center Edition version 2002 SP3.
TIA.
Subject: Re: Cannot run POV-Ray from Windows batch scripts
Date: 21 Jun 2009 01:49:59
Message: <4a3dca07@news.povray.org>
> this error message:
Sounds like you've already got a copy running and don't have "allow
multiple instances" set in the options.
-- Chris
Date: 21 Jun 2009 02:10:00
Message: <web.4a3dcdebe8920bce78641e0c0@news.povray.org>
I have Keep Single Instance unchecked.  I keep an interactive POV session
running so that the /NR from the batch script doesn't close all my editor
files.
Date: 21 Jun 2009 06:00:01
Message: <web.4a3e03e9e8920bce78641e0c0@news.povray.org>
I found the problem.  Version 3.6.2 was installed in a new directory, but the
PATH variable was set to the old 3.6 directory.
Date: 21 Jun 2009 08:50:00
Message: <web.4a3e2bc1e8920bcec9dd53ff0@news.povray.org>
> this error message:
Sounds to me like you previously had "keep single instance" disabled
("OneInstance=0" in the pvengine.ini), and installing 3.6.2 changed that
setting.
POV-Ray will not accept the /nr or /exit switches in that case if an instance of
POV-Ray is already running.
