POV-Ray : Newsgroups : povray.general : Help. Dialux not Rendering with POV Server Time
20 Nov 2025 01:49:08 EST (-0500)
  Help. Dialux not Rendering with POV (Message 1 to 2 of 2)
Subject: Help. Dialux not Rendering with POV
Date: 10 Jun 2009 18:25:00
Message: <web.4a30327e516eccc9325457420@news.povray.org>
I am getting "PARSE ERROR: This file was created with an unofficial version and
cannot work as-is with this official version."  huh?  Need help, please no
skill here in understanding this or what to do???
Subject: Re: Help. Dialux not Rendering with POV
Date: 11 Jun 2009 02:42:48
Message: <Sxfi6PJISKMKFwT8@econym.demon.co.uk>
DIALUX uses an unofficial version of the POV code, presumably with some
changes to the syntax. POV provides the ability to add a
   #version unofficial ....
directive to scene files that use unofficial syntax, which can be used
to specify the fact that the scene has been created to run with a
specific unofficial syntax.
If your scene happens to not use any of the DIALUX-specific syntax, then
you could try removing the #version directive and see if it runs under
an official version of POV.
If your scene does use DIALUX specific POV syntax, then your scene will
only render in the version of POV modified by DIALUX. I guess you can do
this via the DIALUX interface, or you could launch the DIALUX version of
POV directly without running the DIALUX application. If you installed
DIALUX to the default location, its version of POV should be in
C:\Program Files\DIALux\pvengine.exe.
Mike Williams
Gentleman of Leisure
