POV-Ray : Newsgroups : povray.general : In case your scene parses too slow... Server Time
12 Oct 2025 14:59:30 EDT (-0400)
  In case your scene parses too slow... (Message 1 to 7 of 7)
Subject: In case your scene parses too slow...
Date: 16 Apr 2009 00:10:00
Message: <web.49e6aeec231c37c2255d1edc0@news.povray.org>
.... try copying and pasting the most heavily used macros into the file they are
used in.
For instance, on my Windows XP machine the following code can be sped up to
parse *** 25 TIMES FASTER *** by un-commenting the second line:
#include "rand.inc"
//#macro VRand(RS) < rand(RS), rand(RS), rand(RS)> #end
#declare R = seed(42);
#declare i = 0;
#while (i < 100000)
  #declare V = VRand(R);
  #declare i = i + 1;
On my Linux machine, it's not that extreme, but still a factor of 12.
Subject: Re: In case your scene parses too slow...
Date: 16 Apr 2009 11:34:57
Message: <49e75021@news.povray.org>
> used in.
  This is actually a known phenomenon since the dawn of time. Of course
since it's not mentioned in any FAQ or documentation...
Date: 17 Apr 2009 05:10:01
Message: <web.49e84654c058b311f50167bc0@news.povray.org>
> used in.
Yep, I'm using the same scheme in an animation that I'm running--it incorporates
numerous 'generic' macros that I made, which I *could* have saved as .inc files,
but instead are part of the SDL.  Iterated over 200 animation frames, that saves
LOTS of time. I've even done the same thing with several of the mesh-generation
macros in shapes.inc.
KW
Date: 17 Apr 2009 10:16:08
Message: <49e88f28$1@news.povray.org>
"clipka" <nomail@nomail> schreef in bericht
news:web.49e6aeec231c37c2255d1edc0@news.povray.org...
> they are
> used in.
Yes! and .inc content too of course, although less heavy generally speaking.
(Cannot be repeated enough)
Date: 17 Apr 2009 21:22:59
Message: <49e92b73$1@news.povray.org>
> used in.
> #include "rand.inc"
> #declare i = 0;
> #while (i < 100000)
>   #declare i = i + 1;
> #end
This is because each time a macro is called that is in a different file,
the entire containing file is reopened, right? (I remember that from
something in the documentation)
Thinking about that, I'd like to add 'storing macros in memory' for
anything called more than once to the 4.0 SDL wishlist. Most other
compliers do that as far as I know, but I do understand reasons behind
the current behavior, since macros can be huge and all.
Date: 18 Apr 2009 00:30:00
Message: <web.49e95689c058b311f83d00fc0@news.povray.org>
> > used in.
I don't know what is worse:  that it isn't mentioned or that humongous flat
scene files would be the norm was it mentioned in the docs. :P
Date: 18 Apr 2009 04:15:00
Message: <web.49e98b40c058b311b04f58b50@news.povray.org>
Exactly.
I would have taken for granted that if POV 4.0 SDL would operate on bytecode
basis, *all* macros of included files would reside in memory.
But I guess it would also be possible to first compile any files encountered
into bytecode files (unless the compiled files already exist and are
up-to-date), and then load macros from there, using some invocation counter to
decide whether to unload a macro again after use or keep it in memory.
