POV-Ray : Newsgroups : povray.general : How to pass a string from the command line - help? Server Time
27 Feb 2026 03:50:38 EST (-0500)
  How to pass a string from the command line - help? (Message 1 to 7 of 7)
Subject: How to pass a string from the command line - help?
Date: 1 Oct 2008 18:35:00
Message: <web.48e3fa9f79b5340cd8a103ef0@news.povray.org>
The canonical "hello world" scene file has the following components: includes,
camera, light source, a black-and-white checkered plane, and a shiny sphere
sitting on the plane.  I can create a template file "template.pov" that has
some of those components (includes, camera, light source) and a content file
"content.inc" with the others (plane, sphere).  This is easy enough for a
single template file and a single content file -- just replace the plane and
object with '#include "content.inc"' and put the plane and object in
"content.inc" and it just works.
Now what I really want to do is have "content.inc" and "othercontent.inc" and
"stillothercontent.inc" then modify the template to contain '#include Content'
and have the specific include file chosen via the command line something like
this:  povray -Itemplate.pov Declare=Content="content.inc"  Alas, the
command-line version of Declare appears to be limited to floats.  If I
absolutely have to change the #include line in the template to point at the
specific content I will, but that answer is not scalable.  Is there any other
way working from the command line that I can achieve this goal?  Thanks!
Subject: Re: How to pass a string from the command line - help?
Date: 2 Oct 2008 05:22:02
Message: <48e492ba$1@news.povray.org>
"Mathuin" <mat### [at] gmailcom> wrote in message
news:web.48e3fa9f79b5340cd8a103ef0@news.povray.org...
> and
> Content'
> like
Three approaches immediately spring to mind.
1. Write a two line script that first writes the name of your include file
into another include file then calls POV-Ray. For example, a DOS .bat file
could be something like:
  echo #include "%1">contentwrapper.inc
  povray -Itemplate.pov ....
This would write an #include statement embedding the first parameter passed
to the script into the file 'contentwrapper.inc' then it would invoke
POV-Ray with your template.pov scene which would #include contentwrapper.inc
which would, in turn, #include the nested file of your choice.
2. Use floats with an #if or #switch directive to select the #include file
statement of your dreams.
3. Number your include files (e.g. content42.inc) and use the concat
function within your #include statement e.g.
  #include concat("content",Content,".inc")
Chris B.
Date: 2 Oct 2008 06:47:51
Message: <48e4a6d7$1@news.povray.org>
>> Content'
>> something like
It is a lot easier than that:
Use the Include_Header / +HI command-line option. Documentation at
http://www.povray.org/documentation/view/3.6.1/220/ .
	Thorsten
Date: 2 Oct 2008 08:20:00
Message: <web.48e4bc28b41ac224d8a103ef0@news.povray.org>
> >> Content'
> >> something like
>  Thorsten
That's great for the *first* header, but I need it to be at the *end* of the
file, since the content file will have macros and textures and other stuff
that's referred to in the template or included by the template's include files.
Date: 2 Oct 2008 08:24:14
Message: <48e4bd6e$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:48e4a6d7$1@news.povray.org...
>>> Content'
>>> like
> Thorsten
Ah yes. I must have been asleep in the POV101 class when that was covered
Chris B.
Date: 2 Oct 2008 08:30:07
Message: <48e4becf$1@news.povray.org>
news:web.48e4bc28b41ac224d8a103ef0@news.povray.org...
> the
> files.
One way round that is to wrap the contents of the include file in a macro
definition then include the file at the start and run the macro wherever in
your SDL you need it (there may be an even simpler way that I've missed
:o)).
Chris B.
Date: 2 Oct 2008 09:05:00
Message: <web.48e4c0cab41ac224d8a103ef0@news.povray.org>
> >> Content'
> >> something like
>  Thorsten
Wait, I think I get it.  Are you suggesting this?
povray +Icontent.pov +HItemplate.inc
instead of what I was saying before?  If I want to run another content file and
I have another template that has say a different light source or camera
location, I'd run something like this:
povray +Iothercontent.pov +HIdifferenttemplate.inc
Interesting.  I'll have to be very careful with the template files, specifying
exactly what they have to have, but I think it might work.
