POV-Ray : Newsgroups : povray.general : Diffuse, glass texture, different settings in poseray Server Time
29 Sep 2024 05:18:21 EDT (-0400)
  Diffuse, glass texture, different settings in poseray (Message 1 to 4 of 4)
Subject: Diffuse, glass texture, different settings in poseray
Date: 4 Aug 2008 08:45:00
Message: <web.4896f991ae18551ea911672a0@news.povray.org>
Hi
I have worked on rendering .obj files in pov-ray with poseray.
1. There is a setting called "default finish diffuse for maps" at a value of 0.6
? What does that exactly do? and is lower better or higher better?
2. Where can I get a glass texture to my creations?
   Is is just like a normal texture to use on your .mesh file?
3. What are the differences between indoor high quality and outdoor high quality
is that more light on the objects ...when choosing outdoor?
4. Is there any way of choosing another angle of the render in pov-ray or in
poseray for that sake?
Thanks
KC
Subject: Re: Diffuse, glass texture, different settings in poseray
Date: 4 Aug 2008 17:54:00
Message: <48977a78$1@news.povray.org>
karmacowboy wrote:
> Hi
> Thanks
> KC
from the manual:
"Default finish diffuse for maps controls the lightness of the maps
applied to the scene. Default is 0.6. Higher values make map colors more
vivid." Typically the default works well but you can experiment and see
what you like.
You can insert the glass material into any material using the POV-Ray
material tab. See the pov-ray texture section under the materials
chapter in the manual. Glass is one of the default materials that comes
with POV-Ray. You can even type in the POV-Ray code for your own
materials. PoseRay will insert the needed dependencies in the code
before rendering.
As for radiosity I am no expert but higher quality usually minimizes
artifacts but it leads to higher render times. You can go through the
POV-Ray radiosity sample scenes and get more details.
PoseRay has a preview window. Just rotate, pan or zoom the view using
the mouse.  If you are using a small screen just click on the preview
tab "stay on top" in the camera section. This will bring the preview
window to the top. POV-Ray will render the scene using the same camera
that was used in PoseRay.
I recommend you go through the manual. It has some tutorials.
FlyerX
Date: 4 Aug 2008 19:31:45
Message: <48979161@news.povray.org>
> of 0.6 ? What does that exactly do? and is lower better or higher better?
I think you can learn more by changing the value and comparing the images
than by getting an explanation of what it's for. Play around, experiment!
> in poseray for that sake?
Yes, you can change the vectors in the camera{} block. I never used poseray
so I have no idea if it provides any UI to change that easily.
Date: 7 Aug 2008 12:08:45
Message: <489b1e0d$1@news.povray.org>
karmacowboy nous illumina en ce 2008-08-04 08:44 -->
> Hi
It control how much if the incoming light effectively illuminate the texture.
Higher values make the texture brighter and can cause oversaturation in some cases.
Lower values will make it darker.
None is "better", it all depends on what effect you want.
POV-Ray's default diffuse, if not specified otherwise, is 0.8.
Just add a transparent texture and an interior statement where you set the ior,
mass coloration(fade_color, fade_distance and fade_power), optionaly the
dispersion amount and sampling. You can also add some media. If you use media,
you need to add "hollow" to your object to allow it to contain the media.
Typical ior for glass is 1.5. It can range from 1.4 to almost 2 for glass.
Water's ior is about 1.33, and depend on temperature and disolved substances.
Diamond's ior is 2.5, the highest for common natural substances.
Essentialy, the recursion level. Exterior scenes usualy only need
recursion_level 1 or maybe 2, interior scenes often need at least 2, end often more.
In outdoor scenes, you mostly trace to the sky of far away objects.
In interior scenes, you almost always trace to the walls and other objects.
outdoor high quality use recursion_level 1 and count 500.
indoor high quality use recursion_level 3 and count 400.
You can change the camera location, you can also use rotate and translate.
You can change the angle, add "angle Angle_of_View" or the direction vector:
larger will reduce the angle of view, smaler will whiden it.
> Thanks
> KC
Any society that would give up a little liberty to gain a little security will
deserve neither and lose both.
Benjamin Franklin
