POV-Ray : Newsgroups : povray.general : Pattern function errors Server Time
29 Sep 2024 05:14:05 EDT (-0400)
  Pattern function errors (Message 1 to 6 of 6)
Subject: Pattern function errors
Date: 6 Jul 2008 23:55:00
Message: <web.487192ebe6f38171eb867ce10@news.povray.org>
I am having problems with the following pattern:
pigment
 function {sqrt(pow(x,2) + pow(z,2)) / cos(asin(abs(y)))}
 pigment_map
  [0 color rgb 0]
  [1 color rgb <0,1,0,>]
POV-Ray gives the following error:
"Parse Error: Floating-point exception detected in function ''. Your function
either attempted a division by zero, used a function outside
its domain or called an internal function with invalid parameters."
Could somebody please explaing to me why this is and what I can do to fix it?
-Mike
Subject: Re: Pattern function errors
Date: 7 Jul 2008 02:39:58
Message: <4871ba3e@news.povray.org>
> pigment
>  pigment_map
>   [0 color rgb 0]
The Error says it all: You're dividing by zero. Somewhere along the
cosine of asin(abs(y)) the result is 0, which is what you'll be dividing by.
Tim
Date: 7 Jul 2008 03:30:01
Message: <web.4871c5b183e204bdeb867ce10@news.povray.org>
Tim Nikias <JUS### [at] gmxnetWARE> wrote:
> > pigment
> >  pigment_map
> >   [0 color rgb 0]
> Regards,
> Tim
I've tried changing the denominator of the fraction to
max(cos(asin(abs(y))),0.001) so that it doesn't divide by zero, but it has no
effect.
-Mike
Date: 7 Jul 2008 04:42:13
Message: <OuZ4ZaDSbdcIFwJd@econym.demon.co.uk>
>pigment
> pigment_map
>  [0 color rgb 0]
The problem is that asin(foo) is only defined for values of foo between
-1 and +1. If, say y=3 then there is no asin(abs(3)) and you get the
second cause of that error message "your function ... used a function
outside its domain"
If you apply the pigment to an object that lies between y=-1 and y=1,
then it works.
sphere {0,1
  scale <5,0.5,5>
  pigment{
   pigment_map {
    [0 color rgb 0]
If you want to use it on an object that doesn't lie within that region,
then you need to consider what colour you want to have for points
outside that region and code it accordingly.
Mike Williams
Gentleman of Leisure
Date: 7 Jul 2008 06:23:33
Message: <4871eea5@news.povray.org>
> effect.
Mike Williams has the answer, its not just division by zero, but asin(x)
doesn't return proper results for values outside of the -1 to 1 range.
Tim
Date: 7 Jul 2008 10:55:04
Message: <web.48722d2383e204bd4d862de40@news.povray.org>
Thanks for the answer!
What's odd is that you can't scale the pigment either. For instance, the
following produces errors.
sphere {0,1
  pigment{
   pigment_map
    [0 color rgb 0]
 scale y/2
 translate y
Shouldn't the function be evaluated to completion before the pigment gets
scaled?
-Mike
