POV-Ray : Newsgroups : povray.general : Order of texture and pigment matter? Server Time
12 Apr 2026 03:44:57 EDT (-0400)
  Order of texture and pigment matter? (Message 1 to 9 of 9)
Subject: Order of texture and pigment matter?
Date: 12 May 2008 18:25:00
Message: <web.4828c29b90917db34a296dd40@news.povray.org>
I don't understand something.  When I use the following code:
#declare testfinish = finish {ambient 0.7}
triangle {
    v0 v1 v2
       pignment { color Red }
      testfinish
 I get this error:
File: jaime.inc  Line: 94
File Context (5 lines):
    v0 v1 v2
      pigment { color Red }
      testfinish
Parse Error: No matching } in 'texture', finish identifier found instead
But if I just switch the order of pigment and testfinish, as follows, the scene
renders as I expect:
triangle {
    v0 v1 v2
      testfinish
The same is true if I don't use the #declare, but just use the finish keyword
directly:
triangle {
    v0 v1 v2
I've seen this kind of thing before and always "just make it work," but I'd love
to know what's actually happening here.
Subject: Re: Order of texture and pigment matter?
Date: 12 May 2008 19:30:51
Message: <4828d32b$1@news.povray.org>
"wealthychef" <nomail@nomail> wrote in message
news:web.4828c29b90917db34a296dd40@news.povray.org...
> triangle {
>    v0 v1 v2
>    texture {
>      testfinish
> I get this error:
>    v0 v1 v2
>    texture {
>      testfinish
> scene
> triangle {
>    v0 v1 v2
>    texture {
>      testfinish
actually I wouldn't have expected that to work, unless testfinish is
considered a complete texture by POV-Ray.
cu!
Date: 12 May 2008 19:55:00
Message: <web.4828d8b0b71ebc3b4a296dd40@news.povray.org>
> > scene
> > triangle {
> >    v0 v1 v2
> >    texture {
> >      testfinish
> cu!
Care to expand on that a little?  Why wouldn't it work?   What is going on?
Clue, please.  :-)
Date: 12 May 2008 20:25:16
Message: <4828dfec$1@news.povray.org>
> on?
> Clue, please.  :-)
POV finds a finish identifier, not a finish statement,
identifiers and statements aren't interchangeable.
It expects usage like ...
#declare testfinish = finish {ambient 0.7};
triangle {
    v0, v1, v2
      pigment { Red }
      finish { testfinish }
Declare statements shouldn't be confused with macros.
A macro substitutes the lines directly into the calling
code instead of using identifiers. Example...
#macro testfinish() finish {ambient 0.7} #end
triangle {
    v0, v1, v2
      pigment { Red }
      testfinish()
Here testfinish() is replaced by "finish {ambient 0.7}"
which is a finish statement instead of a finish identifier.
Date: 13 May 2008 03:38:26
Message: <48294572$1@news.povray.org>
"wealthychef" <nomail@nomail> schreef in bericht
> triangle {
>    v0 v1 v2
>    texture {
>      testfinish
I think this should be written as:
triangle {
   v0 v1 v2
      finish {testfinish}
Date: 13 May 2008 05:31:03
Message: <48295fd7$1@news.povray.org>
You are correct, it is no legal syntax, but the parser is flexible enough to
accept it anyway.
	Thorsten
Date: 13 May 2008 12:30:00
Message: <web.4829c11eb71ebc3b4a296dd40@news.povray.org>
> > on?
> > Clue, please.  :-)
> triangle {
>     v0, v1, v2
>     texture {
>       pigment { Red }
> triangle {
>     v0, v1, v2
>     texture {
>       pigment { Red }
>       testfinish()
thank you.  This point has been confusing me for years about Povray, as I only
occasionally dabble in it.  So it seems as though in a #declare statement, the
"finish {ambient 0.7}" piece is somehow compiled (?) into a "finish
identifier?"   What is the difference between an identifier and a statement?
Is this true:  "finish" is to "identifier" in Povray as "integer" is to
"variable" in C?
Aha! I think I get it:
If I were to say
#declare testtexture texture { pigment {Red} finish {ambient 0.7} };
I then use it like this:
triangle {
v0,v1,v2
 texture {testtexture}
Thank you.  It's interesting and revealing.
Date: 13 May 2008 13:55:00
Message: <web.4829d5a3b71ebc3b653c34500@news.povray.org>
Actually, it might make more sense in explaining that macro to insert a value as
in:
#macro testfinish(V) finish {ambient V} #end
That way, you could change the value (V) when calling the macro, like so:
testfinish(.7)
-- Dave
> > > on?
> > > Clue, please.  :-)
> > triangle {
> >     v0, v1, v2
> >     texture {
> >       pigment { Red }
> > triangle {
> >     v0, v1, v2
> >     texture {
> >       pigment { Red }
> >       testfinish()
> "variable" in C?
> If I were to say
> triangle {
> v0,v1,v2
Date: 13 May 2008 18:00:48
Message: <482a0f90$1@news.povray.org>
> only
> the
> statement?
> "variable" in C?
Close, testtexture is a variable, the contents of testtexture is
a finish identifier. The statement after "#declare testtexture =" is
evaluated, found to be a finish, and stored in testtexture as a
finish identifier. An identifier is most like a pointer in C...
> If I were to say
Right, but with the "="
> triangle {
> v0,v1,v2
Glad to help.
