I'm nearly sure the answer to this question is a big NO but anyway:
Is it possible to have an object which is transparent for the whole scene but
opaque for another single object. The idea is to reach the effect (in an
animation) of objects dissappearing behind apparently non-existing objects.
So my first guess is to define an object this way:
object{target}
object{<x,y,z> does not interact with nothing but with object{target} }
or
object{target}
object{<x,y,z> completly transparent but for object{target} }
I know it sounds stupid but DON'T SHOOT ME I'M ONLY THE PIANO PLAYER
thanks in advance
"kike" <dry### [at] hotmail com> wrote in message
news:web.48183bc4aed456fcbe7bfb550@news.povray.org...
> but
> objects.
You could fairly simply achieve something pretty similar if you can define
the shape of your 'transparent' object as a prism with the outline of the
shape as it would appear from the camera position.
Here's my thinking:
1. Define a prism object with a conic_sweep that starts back beyond the
object you wish to dissappear and that converges to a single point at the
camera position.
2. This object won't appear in the scene, but you can use it in a CSG
operation to cut away the part of the dissappearing object that would be
'concealed' by the 'transparent' object.
Clearly shadows and mirrored reflections could interfere with this effect,
but the complexity of dealing with/faking those depends on the details of
the scene/animation you're trying to build.
Chris B.
"Chris B" <nom### [at] nomail com> wrote in message
news:481844dc$1@news.povray.org...
BTW. You can define a prism with the outline of more or less any shape you
can define in POV-Ray by rendering an image of it with sufficient contrast,
loading the bitmap image into Inkscape, using 'Path', 'Trace Bitmap' and
saving as a POV-Ray prism object.
Chris B.
> Regards,
> Chris B.
Thanks Chris, you gave me the clue. It was simpler than I thought, the answer
for my particular problem is to use CGS (difference). As simpler than that.
Actually now I see it is a quite stupid question, jajaja, look at this
www.enriquesahagun.es/cgsperiment.avi
thanks again!!!
Subject: Re: selective transparency of objects
Date: 30 Apr 2008 08:42:29
Message: <48186935@news.povray.org>
The way I'd do it:
1: Render one version of the scene, with the object that you want to vanish.
2: Render another version, without the object.
3: Render a mask version, which contains the "blocking" object as solid
full-ambient white, and everything else as black.
Ensure that the camera is positioned in the same way for all three renders.
4: Render a fourth scene:
#declare pigMask=pigment { image_map { png "mask.png" } }
#declare pigWith=pigment { image_map { png "with.png" } }
#declare pigWithout=pigment { image_map { png "without.png" } }
plane { -z,0
pigment { pigment_pattern { pigMask }
pigment_map {
[0 pigWith]
[1 pigWithout]
translate -.5
finish { ambient 1 diffuse 0 }
camera { orthographic
right x
up y
direction z
location -z
Hope this helps,
John
Date: 30 Apr 2008 11:25:56
Message: <48188f84@news.povray.org>
Download 'cantplay.jpg' (15 KB)
Preview of image 'cantplay.jpg'
"Bryan Valencia" <no### [at] way com> wrote in message
news:48188f84@news.povray.org...
I couldn't play it either.
Chris B nous illumina en ce 2008/04/30 13:52 -->
Play just good with IrfanView.
Never underestimate the power of stupid people in large groups.
Bryan Valencia <no### [at] way com> wrote:
SORRY, dont know why the codec I used doesnt work, I'll try with another codec.
But anyway, it was just this:
difference{
sphere{... translate clock*x}
cylinder
this way you can see the sphere while is not in contact with the cylinder (the
cylinder, this way is not visible). Once the sphere is in contact with the
cylinder, the sphere disappears as well. So you reach the effect that there is
something invisible avoiding the visibility of the sphere.
As it turns out, if I save it to my desktop and play it from there it works fine.
> difference{
> cylinder
