POV-Ray : Newsgroups : povray.general : Is it possible to have optional arguments in macros. Server Time
29 Sep 2024 07:22:17 EDT (-0400)
  Is it possible to have optional arguments in macros. (Message 1 to 4 of 4)
Subject: Is it possible to have optional arguments in macros.
Date: 29 Apr 2008 07:05:01
Message: <web.4816ffbf42eefae121397d5a0@news.povray.org>
Hello everyone,
I was wondering if it is possible to develop a way so that the M22 object may
not necessarily need all 4 textures.  Whether it be by making optional macros
or special if statements that compare textures (because I could make a null
texture).  Thank you for you time and help!
The code of my macros is below.
#macro M22 (BodyTexture1, BodyTexture2, ConeTexture, ImperfectionTexture)
        object{
                union{
                        #switch(CSGOrIsosurface)
                                #case(1)
                                        object{CSGM22Chassis
                                        texture {BodyTexture1}
                                        texture {BodyTexture2}
                                        texture {ConeTexture} //This is used
with any texture to create a different coloured cone for the plane
                                        texture {ImperfectionTexture}
                                        translate z*15}
                                #break
                                //--OR--
                                #case(2)
                                        object{MeshM22Chassis
                                        //the next 2 lines, adjust for blenders
exporter
                                        translate z*-1.5
                                        scale 10
                                        translate z*15
                                #break
                                //--OR--
                                #case(3)
                                        object{IsoM22Chassis
                                        translate z*15}
                                #break
                        object{Cockpit interior{ior 1.3}}
                        scale 1/2  //make this plane a realistic size
                        //add any weapons here
Subject: Re: Is it possible to have optional arguments in macros.
Date: 29 Apr 2008 11:24:17
Message: <48173da1$1@news.povray.org>
"Bridgeofstraws" <bri### [at] inboxcom> wrote in message
news:web.4816ffbf42eefae121397d5a0@news.povray.org...
> Hello everyone,
> may
> macros
> null
>        object{
>                union{
>                                #case(1)
> used
>                                        translate z*15}
> ... snip ...
I don't think you can 'compare' textures. However, A number of alternative
ideas do spring to mind to enable you to selectively use them, for example:
1.  You could define a completely transparent texture and pass that into the
macro whenever you don't want to use an actual texture for that layer. e.g.:
 #declare MyBlank = texture {pigment {rgbt 1}}
 M22(MyBlank, MyBlank, texture {...}, etc...
2.  You could use global identifiers instead of parameters, then test for
their existence within your macro e.g.:
#declare MyGlobalBodyTexture1 = texture { ...}
#macro M22 ()
... snip ...
   #ifdef (MyGlobalBodyTexture1)
     texture {MyGlobalBodyTexture1}
   #ifdef (MyGlobalBodyTexture2)
     texture {MyGlobalBodyTexture2}
... etc.  ...
Making sure that at least one texture is always defined. You could do that
by using #ifndef to set a default texture whenever it hasn't been set
globally outside the macro call e.g.:
#ifndef(MyGlobalConeTexture)
  #local MyGlobalConeTexture = texture {pigment {color Red}}
>                                #break
>                                //--OR--
>                                #case(2)
> blenders
p.s.  If you want to use the same textures for all of your different
possible chassis object definitions, you should be able to reduce your code
with:
object {
  #case(1) CSGM22Chassis #break
  #case(2) MeshM22Chassis #break
  #else       IsoM22Chassis
... etc. ...
or by passing the object in as a parameter to the macro call, so that it
always has the same name.
Chris B.
Date: 29 Apr 2008 14:30:01
Message: <web.481769204b6dcecdd67c2c340@news.povray.org>
I've used your suggestions and it works great! Thanks for the help Chris.
Date: 29 Apr 2008 16:33:52
Message: <48178630@news.povray.org>
> texture).
One possibility would be to provide flags as explicit parameters as in
#macro M22_INTERN(USE_T1, T1, USE_T2, T2)
#if (USE_T1)
   texture {T1}
and provide convenience macro wrappers such as
#macro M22_1(T)
   M22_INTERN(true,T,false,T)
#macro M22_2(T1,T2)
   M22_INTERN(true,T1,true,T2)
But actually, I think in your case it is simply possible to write
#macro M22 (TextureList)
   texture {TextureList}
and calling it like
M22(texture {BodyTexture1} texture {BodyTexture2})
