POV-Ray : Newsgroups : povray.general : Problems with iterations Server Time
27 Feb 2026 10:30:27 EST (-0500)
  Problems with iterations (Message 1 to 10 of 16)
Subject: Problems with iterations
Date: 10 Jan 2008 01:20:01
Message: <web.4785b89a636bc06df6ab856c0@news.povray.org>
Check out this test scene:
#local i = 0;
#local numerator = 1;
#local divisor = 6;
#while(i < numerator)
 #local i = i + numerator/divisor;
 #debug concat("i = ", str(i, 0, -1),"\n")
Shouldn't the iterations stop when i = 1? What am I doing wrong?
Subject: Re: Problems with iterations
Date: 10 Jan 2008 02:25:00
Message: <web.4785c7acf1dc5f73f6ab856c0@news.povray.org>
> #local i = 0;
> #local divisor = 6;
> #end
Just to be clear, the last entry printed to the Messages panel is "i =
1.166667".
Date: 10 Jan 2008 03:02:17
Message: <op.t4pe93otcs6ysw@e6600.bredbandsbolaget.se>
>> #local i = 0;
>> #local divisor = 6;
>> #end
> 1.166667".
You should move the variable update (i.e. "#local i = i +...") to the
end
of the loop. You should also realize that comparing floating point numbe
rs
like this is problematic at best, and should generally be avoided.
FE
Date: 10 Jan 2008 03:45:01
Message: <web.4785da57f1dc5f73f6ab856c0@news.povray.org>
> >> #local i = 0;
> >> #local divisor = 6;
> >> #end
> > 1.166667".
> end
> rs
> FE
If I move it to the end it will merely say "i = 1.000000". The condition still
should have failed in this case. I.e., the loop should not run past 0.833333.
Date: 10 Jan 2008 04:00:00
Message: <web.4785ddf4f1dc5f73f6ab856c0@news.povray.org>
> >> #local i = 0;
> >> #local divisor = 6;
> >> #end
> > 1.166667".
> end
> rs
> FE
I moved the incrementor to the end of the loop as you suggested:
#local i = 0;
#local divisor = 6;
The result, however, lists seven iterations:
i = 0.000000
i = 0.166667
i = 0.333333
i = 0.500000
i = 0.666667
i = 0.833333
i = 1.000000
There should only be six!
Date: 10 Jan 2008 04:04:44
Message: <4785dfac$1@news.povray.org>
> i = 0.000000
> i = 0.166667
> i = 0.333333
> i = 0.500000
> i = 0.666667
> i = 0.833333
> i = 1.000000
I wouldn't mind betting that 1/6 cannot be exactly represented by a floating
point number.  So by the time you have summed 6 of them you actually have
0.9999999999999999999999 stored and not 1.0000000000000000 as you expect.
The output only shows 1.00000 because it is rounded.
You shouldn't rely on floating point numbers being exact like you are doing,
find another way to do it.
This goes for any programming language using the normal floating point data
types by the way, not just POV.
Date: 10 Jan 2008 06:33:25
Message: <47860285@news.povray.org>
  You have found the inaccuracies of floating point numbers.
  If you want an exact number of iterations, use integers, and at the
beginning of the loop, calculate the actual value you want to use from
that integer loop counter.
  For example, assume you want a loop with a variable which goes from
0 to 1 at steps of 0.1, and stops before it reaches the 1. The correct
way to do that is:
#declare Index = 0;
#while(Index < 10)
  #declare Value = Index/10;
  ... (the body of the loop here, which uses 'Value') ...
  #declare Index = Index+1;
  This would be the *wrong* way of doing it:
#declare Value = 0;
#while(Value < 1)
  #declare Value = Value + 0.1;
Date: 10 Jan 2008 15:46:21
Message: <4786841d$1@news.povray.org>
>> #local i = 0;
>> #local divisor = 6;
>> #end
> 1.166667".
Change it to this:
#local i = 0;
#local divisor = 6;
and it will end before reporting i>=0.
John
Date: 10 Jan 2008 16:05:00
Message: <web.478687b0f1dc5f73d410b38f0@news.povray.org>
> way to do that is:
> #declare Index = 0;
> #while(Index < 10)
> #end
> #declare Value = 0;
> #while(Value < 1)
> #end
I'm wondering if simply changing the condition to "i < 0.999999" is sufficient.
The likelihood of the variable falling outside this range is pretty slim. Also,
to how many decimal places does POV-Ray calculate? I thought the "system
specific" option in the "str" function returned values using this amount.
Date: 10 Jan 2008 16:17:35
Message: <47868b6f$1@news.povray.org>
"To how many decimal places does POV-Ray calculate" is the wrong
question to ask. POV-Ray asks your CPU to do floating-point
calculations, that's all. POV-Ray doesn't do numerical calculations in
any different way than the rest of your computer.
Also, floating-point numbers don't even work in terms of "decimal places".
Use this:
#local i = 0;
#local divisor = 6;
#while(i < divisor)
  #local x = i*numerator/divisor;
  #debug concat("x = ", str(x, 0, -1),"\n")
  #local i = i + 1;
and be done with it.
