POV-Ray : Newsgroups : povray.general : Mechsim for still images Server Time
13 Oct 2025 11:41:05 EDT (-0400)
  Mechsim for still images (Message 1 to 10 of 10)
Subject: Mechsim for still images
Date: 4 Jan 2008 14:05:01
Message: <web.477e8259a691122b13b59ba90@news.povray.org>
Hello,
I want to use mechsim to place spheres in a still image. So far I'm able to
produce an animation that moves the spheres in the scene and generates a new
sphere in each frame (derived from tutorial03.pov). For my still image, I only
need the last frame of course.
How can I make mechsim iterate over a given number of "frames" (of which no
images should be generated to save time) and let megapov render the resulting
scene (ie, last frame only)?
Boris
Subject: Re: Mechsim for still images
Date: 4 Jan 2008 16:45:00
Message: <web.477ea86334268d352a7b15450@news.povray.org>
"borix" <nomail@nomail> wrote:
> Hello,
> Regards,
> Boris
http://www.povray.org/documentation/view/3.6.1/216/
2.1.2.1.3 Subsets of Animation Frames
Hope this helps
Leef_me
Date: 4 Jan 2008 17:26:16
Message: <477eb288@news.povray.org>
> Hope this helps
I think it won't. The way MegaPOV mechsim works for animations is by
loading the simulation data from disk, processing it some more, saving
it back, and rendering. If you render only the last frame, it would look
like the first frame...
There must be a way to do it with megapov settings on the mechsim block,
but I have never used it. I only rendered the sample scenes using mechsim :)
Date: 4 Jan 2008 17:55:00
Message: <web.477eb92534268d3513b59ba90@news.povray.org>
> > Hope this helps
That's right. mechsim doesn't work if you don't start the animation from the
beginning. This is what happens with a new file:
> megapov +sf150 +ef200 +kff1000-j l msim.pov
  0:00:01 Calculating Mechanics Simulation Time=0.0000s (0 percent)
File: msim.pov  Line: 58
File Context (5 lines):
                                save_file "coords.dat"
Parse Error: Attempt to malloc zero size block (File: mechsim.cpp Line: 4420).
Rendering with +sf ... +ef works if there's a MSIM *.dat-file, but then mechsim
just continues where it previously ended.
I use -w1 -h1 to speed up rendering. I haven't found a more clever way yet.
-Boris
Date: 4 Jan 2008 18:06:26
Message: <477ebbf2@news.povray.org>
Considering the text of that message, it looks like a BUG on MegaPOV.
Date: 4 Jan 2008 18:40:00
Message: <web.477ec30c34268d35b16a82110@news.povray.org>
Run your simulation to the point you want, data is saved with the save_file
option.
Edit your Megapov file to only load_file your data.
When you run the file now you should get only the last simulation frame.
StephenS
Date: 5 Jan 2008 04:15:01
Message: <web.477f497834268d35cc1698840@news.povray.org>
> option.
But then I still have to render the first n-1 pictures?
Date: 5 Jan 2008 06:50:00
Message: <web.477f6eb334268d354eeb0f840@news.povray.org>
Choose a larger step_count?
Date: 5 Jan 2008 07:00:01
Message: <web.477f70ca34268d354eeb0f840@news.povray.org>
And lower the number of frames in the animation :-)
Date: 5 Jan 2008 08:20:00
Message: <web.477f83b034268d35cc1698840@news.povray.org>
As in tutorial03.pov, I introduce a new mass in every frame. Therefore,
increasing step_count doesn't help.
I circumvented the problem by placing a large number of masses in the scene to
start with.
