POV-Ray : Newsgroups : povray.general : Selective texture/material loading is possible... Server Time
29 Sep 2024 13:27:49 EDT (-0400)
  Selective texture/material loading is possible... (Message 1 to 1 of 1)
Subject: Selective texture/material loading is possible...
Date: 14 Nov 2007 21:45:00
Message: <web.473bb1b8e22eb663fedbe4b90@news.povray.org>
Selective texture loading is possible...
1. Generate a list of the materials used (manually)
2. declare those materials/textures as simple low res textures
3. load the big long ".inc" file containg large numbers of textures, most of
which you wont load.
4. each material definition is wrapped in a conditional
#if   #then  using the "MATERIALNAME" so that only previously defined materials
are loaded / REdeclared.  all the other material names in the include file will
not be read in because the ifthen statement filtered them out.
5. you have just selectively loaded a material definition libraryfile.
6. definition file can contain large numbers of bitmaps or other
complex files.
PS  im sure i've seen this system somewhere anyone
