POV-Ray : Newsgroups : povray.general : Cylindrical projection Server Time
29 Sep 2024 15:28:55 EDT (-0400)
  Cylindrical projection (Message 1 to 10 of 13)
Subject: Cylindrical projection
Date: 30 Oct 2007 12:20:00
Message: <web.472766c1f915cc94f104cee20@news.povray.org>
Hello
Please help me to find some details about Cylindrical projection.
Thanks.
Subject: Re: Cylindrical projection
Date: 30 Oct 2007 13:48:42
Message: <47277c8a@news.povray.org>
"Hamed Ahmadi" <h.a### [at] hotmailcom> wrote in message
news:web.472766c1f915cc94f104cee20@news.povray.org...
> Hello
> Thanks.
Hi Hamed,
There's a 'cylinder' camera type that you can find in the POV-Ray help file
by searching for 'cylindrical projection' in the index. There are a few
types of projection described there and the 'panoramic' camera type also
gives a form of cylindrical projection.
Also it's possible to project an image (or any other pigment) onto a
cylinder (or indeed onto any other object) using a cylindrical warp. Look
for 'cylindrical warp' in the help where there's an example of using the
cylindrical warp to project a hexagonal pigment onto a cylinder.
Hope that helps. Otherwise, are you able to be a bit more precise about what
you're trying to do?
Chris B.
Date: 1 Nov 2007 08:35:01
Message: <web.4729d5115849c6ccf104cee20@news.povray.org>
Thanks for your answer,
actually i'm going to render some 3d models on a cylindrical screen with a
projector and i don't know how to reduce the distotion.
so i'm searching for a way to preduce a distorted screen that looks undistorted
on the cylindrical screen. Could you help me please?
Thanks in advance.
Date: 1 Nov 2007 10:06:06
Message: <4729eb5e@news.povray.org>
web.4729d5115849c6ccf104cee20@news.povray.org...
> undistorted
> Thanks in advance.
you could try a cylindrical camera as below.
As you see the scene is very simple : a 1/2 cylinder with a radial pattern.
rendered through a cylindrical camera placed on the axis, the pattern
appears as evenly wide bands.
Is that what you want?
Marc (code below)
#version 3.5;
global_settings {
  assumed_gamma 1.0
background { color rgb <0.1, 0.3, 0.8> }
#declare Cylindrical_projection=1;//Set this value to  1 to render a
#if (Cylindrical_projection)
// cylinder lens for axis distorted field of view
// 1 is vertical cylinder, fixed viewpoint
// 2 is horizontal cylinder, fixed viewpoint
// 3 is vertical cylinder, viewpoint moves along the cylinder's axis
// 4 is horizontal cylinder, viewpoint moves along the cylinder's axis
  cylinder 1            // types 1, 2 ,3, 4
  location <0,0,0>     // position
  right x*5             // horizontal aspect or field of view
  up y*2                // vertical aspect or field of view
  look_at  <0,0,1>      // view
  angle 181
#else
// perspective (default) camera
  location  <2.0, 2.0, -2.0>
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-10, 30, -30>
#declare Bandes= pigment{
radial frequency 10
color_map {
  //  [ END_VAL color red R green G blue B filter F transmit T]
  [ 0.5  color rgb 0]
  [ .5  color rgb 1 ]
  // (---alternative form---)
  //[ 1.0  color rgbf <0.8, 0.8, 0.8, 1.0> ]
} // color_map
intersection{
cylinder{-y,y*1.1,1 texture{ pigment{Bandes}finish {ambient 0 diffuse 0.6}}}
box{<-1,-1.1,0>,<1,1,1> pigment {color rgbt 1}}
no_shadow}
Date: 2 Nov 2007 02:05:01
Message: <web.472acbd45849c6ccf104cee20@news.povray.org>
Hello
as i said before i wanna use a projector and show the scene on a real
cylindrical screen, so i have a question. If i do that with the settings
you mentioned in the previous post, the scene on the screen won't be distorted?
Thanks.
Date: 2 Nov 2007 02:31:44
Message: <472ad260@news.povray.org>
web.472acbd45849c6ccf104cee20@news.povray.org...
> Hello
> distorted?
> Thanks.
It depends on the lense you use.
May  we have some details on the technics involved in this projection?
Marc
Date: 2 Nov 2007 03:00:00
Message: <web.472ad84c5849c6ccf104cee20@news.povray.org>
> Marc
Dear Marc
I don't have any special technic and i just wanna find a way to have
a undistorted scene on a cylindrical screen with a ordinary projector.
of course I prefer to do that by software modification not by hardware
for example i guess there should be a matrix if i used it in my code (directx)
i will have a undistorted scene, but hardware ways may be used too.
Do you know a special lens for that?
Hamed.
Date: 2 Nov 2007 03:39:54
Message: <472ae25a$1@news.povray.org>
web.472ad84c5849c6ccf104cee20@news.povray.org...
> Dear Marc
> (directx)
> Regards,
> Hamed.
Err I must admit that's beyond my knowledge
Marc
Date: 2 Nov 2007 03:50:00
Message: <web.472ae4125849c6ccf104cee20@news.povray.org>
Thanks anyway,
If you find something even a little, please let me know
you know, i am crazy about the subject.
Best wishes,
Hamed.
Date: 2 Nov 2007 04:15:32
Message: <472aeab4$1@news.povray.org>
Hash: SHA1
>> Marc
> Dear Marc
	That's probably not possible. Sure you can find a software
transformation that will compensate the *distortion* (in fact, the
standard POV perspective camera should do it more or less), but your
main problem will be the *focus*. Ordinary projector have lenses
that only produce a sharp image on (or near) a certain plane. The
position of this plane may be adjusted, but it is always a plane.
This means that if your screen is a cylinder, you will have parts of
the screen which are in front of the focus plane and/or other parts
which are behind, and those parts will be out of focus and display a
blurred image.
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFHKuq0d0kWM4JG3k8RAsEpAKCg/Ocd22+biVYciinglHtEPCSz7QCfUAA6
yhqKTNTK9rrwMOh1PuDC7HI=
=s3SH
-----END PGP SIGNATURE-----
