POV-Ray : Newsgroups : povray.general : string interpretation Server Time
13 Oct 2025 16:21:30 EDT (-0400)
  string interpretation (Message 1 to 5 of 5)
Subject: string interpretation
Date: 17 Sep 2007 20:05:00
Message: <web.46ef14c6c496b69291227f400@news.povray.org>
I'm trying to create a sort of "catalog" of textures in the various standard
include files - for instance, "woods.inc" which defines T_Wood1 through
T_Wood35.
After setting up a simple test scene, I convert it into an animation so that
each texture is rendered in its own frame. I find myself wanting to define
the texture that is used based on the frame number thusly:
#declare textString = concat ("T_Wood",str(frame_number,2,0));
texture { textString }
That doesn't work. :(
So am I left with a hand-coded #switch statement with a series of #cases-
#case(n)
#declare MyTexture = texture{T_Wood<n>}
#break
There's no "casting" of a string to any other type. Or is there perhaps some
magic solution I'm not seeing?
The "woods" file is actually pretty easy to enumerate compared to some of
the others - so I'm really after a more general solution. I know I could
whip something up in Perl that would spit out scene files dynamically (and
of course call up POV with input from stdin) but I would like to keep
everything in the POV SDL if possible.
Thanks for any tips/hints anyone can offer.
Subject: Re: string interpretation
Date: 17 Sep 2007 20:35:00
Message: <web.46ef1c5d490f90337d55e4a40@news.povray.org>
Parse_String() might be what you want. See 3.7.16, documentation for the
strings.inc standard include file.
Tom
Date: 18 Sep 2007 00:45:06
Message: <46ef57d2$1@news.povray.org>
Jim nous apporta ses lumieres en ce 2007/09/17 19:59:
> T_Wood35.
> #case(n)
> #break
Already done for you. Look at the portfolio folder and run the various *.ini
files you find there. It will generate all the textures, pigments, materials,
primitives and some more, and the html code to view them in any browser.
For example, you will get 7 wood pages showing 6 wooden textures each.
   It's tough to stay married. My wife kisses the dog on the lips, Yet she won't
drink from my glass!
	Rodney Dangerfield
Date: 18 Sep 2007 19:15:00
Message: <web.46f05b83490f903391227f400@news.povray.org>
Somehow I missed that particular directory - sure enough, it gives me almost
everything I wanted. As I said *any* tips are welcome. Many thanks.
Date: 22 Sep 2007 12:58:00
Message: <46f54998@news.povray.org>
Tried sending that to #debug and got "T_Wood 0"; try this instead:
    #declare textString = concat ("T_Wood",str(frame_number,1,0));
The "L" parameter (the 1 in the middle) is the *minimum* length of the
formatted number, so it doesn't truncate the value.  Didn't try it in a
scene, and didn't use frame_number but rather just a loop index, but it
looks right in the Messages pane.
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
