POV-Ray : Newsgroups : povray.general : How to display image? Server Time
12 Apr 2026 13:18:31 EDT (-0400)
  How to display image? (Message 1 to 7 of 7)
Subject: How to display image?
Date: 17 Sep 2007 19:40:01
Message: <web.46ef104ae7dfafdd3ccd3f470@news.povray.org>
What's the easiest way to display a 2D image, like a phtograph hanging on a
wall. I've tried something like
box {
    < 10, 20, 5 >
    < 10, 22, 7 >
      image_map {jpeg "puppy.jpg"}
      scale 2
but the box shows gibberish.
Thanks in advance!
Pahidla
Subject: Re: How to display image?
Date: 17 Sep 2007 23:23:58
Message: <46EF4523.6010706@joplin.com>
Pahidla wrote:
> Hi,
> box {
>     < 10, 20, 5 >
>     < 10, 22, 7 >
>     pigment {
>       scale 2
> Thanks in advance!
> Pahidla
  By default, the image is mapped onto the x-y-plane. The image is
projected onto the object as though there were a slide projector
somewhere in the -z-direction. The image exactly fills the square area
from (x,y) coordinates (0,0) to (1,1) regardless of the image's original
size in pixels.
What is mostly done is something like this:
  box {
      < 0, 0, 0 >
      < 1, 1, 1 >
     scale 2
     rotate (if needed)
     translate (if needed)
Have Fun!
Date: 18 Sep 2007 03:05:01
Message: <web.46ef777c6a46897c3ccd3f470@news.povray.org>
Thanks!
Is there such a thing as a "rectangle", rather than a "box"?
Thanks again!
Pahidla
Date: 18 Sep 2007 03:58:28
Message: <46ef8524$1@news.povray.org>
web.46ef777c6a46897c3ccd3f470@news.povray.org...
> Thanks!
just scale your box (after the pigment has been applied)to fit your image
ratio
Say for a 800x600 image
//Camera to fit your wish of z up, y forward
  location  <      0,     -12,       0>
  sky       z
  up        z
  right     x* 1.33
  angle          7
  look_at   <      0,      0,       0>
// *******  L I G H T S *******
light_source {
  <0.0, 0.0, 0.0>
  color rgb <1.000, 1.000, 1.000>
  photons {
  translate  <0, -15, 0>
#declare Image =
      texture
         pigment {image_map{jpeg   "Your_image.jpg"}}
         finish {diffuse 0.8}
box {
  0, 1
   texture {Image}
   translate<-.5,-.5,-.5>// to center the box around 0rigin
  scale <1.333, 1.0, 0.01> //to fit image ratio (800/600 almost =  1.333)
  //  you can multiply   by the amount you want, like : scale <1.333, 1.0,
0.01>*10
  rotate 90.0*x  //to face camera
Date: 18 Sep 2007 04:07:38
Message: <46ef874a$1@news.povray.org>
46ef8524$1@news.povray.org...
Even better
scale<Your_image_width / You_image_height, 1, 0.01>  //replace
"Your_image_width" by the actual width of you image , same for the height
Marc
Date: 18 Sep 2007 16:18:59
Message: <46f032b3$1@news.povray.org>
There's polygons.
polygon {
   4,
   <0, 0>, <0, 1>, <1, 1>, <1, 0>
      pigment { image_map { png "plasma2.png"  } }
      finish { ambient 1 diffuse 0 }
    //scale and rotate as needed here
Date: 18 Sep 2007 18:04:48
Message: <46f04b80$1@news.povray.org>
"Pahidla" <dol### [at] yahoocom> wrote in message
news:web.46ef777c6a46897c3ccd3f470@news.povray.org...
> Thanks!
there are polygons, and triangles.  If I want to create a rectangle, I use
this macro:
#macro Quad(P1,P2,P3,P4)
 triangle {P1,P2,P3} triangle {P1,P3,P4}
(you'll have to put this inside a mesh, like this:
mesh {
    Quad(<0,0,0>,<0,1,0>,<1,1,0>,<1,0,0>)
You could even add uv-coordinates, like this: (untested code!!!)
    triangle {P1,P2,P3 uv_vectors <0,0>,<0,1>,<1,1>}
    triangle {P1,P3,P4 uv_vectors <0,0>,<1,1>,<1,0>}
mesh {
        uv_mapping pigment {image_map {jpeg "puppy.jpg" interpolate 2}}
        finish {ambient 0 diffuse 1}
cu!
