POV-Ray : Newsgroups : povray.general : projective transformations Server Time
26 Dec 2025 18:25:23 EST (-0500)
  projective transformations (Message 1 to 4 of 4)
Subject: projective transformations
Date: 25 Jul 2007 11:20:02
Message: <web.46a7697cabf1811949aa3f520@news.povray.org>
Is it possible to use projective transformations in povray?
I'd need to adapt a checker to an irregular four-sided, planar figure and
this cannot be done using only affine transformations such as rotations,
scaling transformations, translations and their compositions.
Thank you,
mimmo
Subject: Re: projective transformations
Date: 25 Jul 2007 15:37:23
Message: <46a7a673@news.povray.org>
"mimmo" <dom### [at] unitnit> wrote in message
news:web.46a7697cabf1811949aa3f520@news.povray.org...
> Thank you,
> mimmo
Hi Mimmo,
I believe you should be able to do this by defining a function to use as a
pigment (though I've not tried it and don't know the maths you'd need). If
my understanding of this is correct, you should be able to use the checker
pattern in the function and apply a suitable mathematical
deformation/transformation to it. See "Function as pattern" in the help
(Section 3.5.11.15 in the Windows version.), which actually uses the checker
pattern option in one of the examples.
A somewhat less sophisticated approach is simply to project light (a point
source) through a patterned surface. The following example illustrates this
excessively crude technique. This technique is obviously limited in what it
can achieve and I wouldn't recommend using it if you need anything much less
trivial than this example. Nevertheless, I thought I'd throw it in as you
may just find it meets your needs and it's probably an order of magnitude
easier to visualise.
camera {location <-0.3, 0.8,-2> look_at  <0,0,0>}
light_source { <-20, 20, -20> color rgb <1,1,1>}
box {0,1 pigment {color rgb 1}}
box {0,-1 pigment {color rgb 1} translate z*0.5}
plane{-y,0
  pigment{checker
    color rgbf <4,1,0,0.4>
    color rgbf <1,1,1,1>
    scale 0.1
  rotate -20*x translate 4*y
  no_image
Chris B.
Date: 25 Jul 2007 16:15:51
Message: <46a7af77$1@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:46a7a673@news.povray.org...
>> Thank you,
>> mimmo
> Hi Mimmo,
> ... snip ...
Here's what I arrived at through messing about for a couple of minutes with
that trying to get a perspective-like pattern:
camera {location <0, 0,-20> look_at  0}
#include "functions.inc"
#declare FOO = function {pigment { checker scale 10} }
plane {-z,0
     function { FOO(x/y*20,sqrt(y)*100,z).green}
Chris B.
Date: 26 Jul 2007 03:35:00
Message: <web.46a84e19cb3fb5f749aa3f520@news.povray.org>
> > ... snip ...
> plane {-z,0
>    pigment {
> Regards,
> Chris B.
Thanks to all, it's just what I need to know.
mimmo
