POV-Ray : Newsgroups : povray.general : Camera distortions Server Time
27 Feb 2026 17:13:55 EST (-0500)
  Camera distortions (Message 1 to 3 of 3)
Subject: Camera distortions
Date: 4 Jun 2007 18:30:02
Message: <web.466491cb6eee4bf72f54749c0@news.povray.org>
Hi, All.
Please help.
In this post:
http://news.povray.org/povray.general/thread/%3Cweb.4640d4eb7a83c8141d1bbab40%40news.povray.org%3E/
I tried create glass fractal.
Now tried to render one density map df3 file, and get strong radial
distortions.
This is my result: http://www.geocities.com/gplflame/test.jpg.
This is object from  which df3 file created:
http://www.geocities.com/gplflame/demo2.html
I want insert some others object to density files, and I need more
precision.
here is my pov file:
#include "metals.inc"
#declare TWOPI = 6.283185307179586476925287;
#declare RADIUS = 1;
#declare NX = 1;
#declare NY = 1;
#declare NZ = 1;
#declare DD = <NX,NY,NZ>;
#declare CC = DD / 2;
#declare VP = <0, 0 , NZ  * 1.4>;
global_settings {
 ambient_light <1,1,1>
 assumed_gamma 1
   location VP
   up y
   right x * 1.3333
   sky <0,0,-1>
   look_at <0,0,0>
light_source {
   VP + <0,0,NZ * 2>
   color rgb <1,1,1>
   media_interaction on
   media_attenuation on
   shadowless
#declare theinterior = interior {
   media {
      emission 1
      absorption 0.4
      density {
                  density_file df3 "example.df3"
   interpolate 2
   color_map {
      [0.00 rgb <0,0,0>]
          [0.33 rgb <0,0,1>]
                        [0.66 rgb <0,1,0>]
                        [1.00 rgb <1,0,0>]
box {
   <0,0,-0>, <1,1,1>
   pigment { rgbf <1,1,1,1> }
   interior { theinterior }
   translate <-0.5, -0.5, -0.5>
   hollow
Subject: Re: Camera distortions
Date: 4 Jun 2007 19:32:29
Message: <4664a10d$1@news.povray.org>
flame-mike nous apporta ses lumieres en ce 2007/06/04 18:27:
> Hi, All.
> Please help.
> In this post:
> distortions.
> precision.
You don't use any metalic texture, this can go.
Firstly, try using interpolate 1. interpolate 2 often introduce unwanted noise
and artefacts. In your case, you probably see media in areas that have a density
of zero and be totaly transparent.
If that don't produce a result that's good enough, try the following:
You may scale down in the direction of the camera.
You may alter the color_map and the emission and absorbtion like this:
>    media {
>       emission 1
>       absorption 7
>       density {
>    interpolate 1
>    color_map {
>       [0.00 rgb <0,0,0>]
>       [0.33 rgb <0,0,1>*5]
>       [0.66 rgb <0,1,0>*5]
>       [1.00 rgb <1,0,0>*5]
This will make your media dencer, and thus more "solid". The increased
absorbtion is to compensate the increased brightness of the emissive part.
You probably need to also increase the samples value quite a bit, as your
density pattern is very complex. Try something like 100 as a starter.
Date: 5 Jun 2007 12:45:02
Message: <web.4665928189945754c79a660c0@news.povray.org>
This is now good: http://www.geocities.com/gplflame/test1.jpg
Alain, thank you very much.
any other suggestions to make this more glassy.
And I have another question. How I made rendered box with same size as
image?
//#include "metals.inc"
#declare NX = 1;
#declare NY = 1;
#declare NZ = 1;
global_settings {
 assumed_gamma 1.6
   location VP
   up y
   right x * 1.3333
   //direction <0, 0, 0>
   sky <0,0,-1>
   look_at <0,0, 1>
light_source {
   VP + <0,0,NZ * 2>
   color rgb <1,1,1>
   shadowless
   media {
      emission 25
      absorption 2
      samples 140
      scattering { 1, 0.5 }
      density {
   interpolate 1
   color_map {
      [0.00 rgb <0,0,0>]
                        [0.33 rgb <0,0,0.065>*1.1]
                        [0.66 rgb <0.015,0.015,0.005>*1.2]
                        [1.00 rgb <0.15,0,0.035>*1.3]
box {
   <0,0,-0>, <1,1,1>
   hollow
> > Hi, All.
> > Please help.
> > In this post:
> > distortions.
> > precision.
> >    media {
> >       emission 1
> >       absorption 7
> >       density {
> >    interpolate 1
> >    color_map {
> >       [0.00 rgb <0,0,0>]
> Alain
