POV-Ray : Newsgroups : povray.general : Problem with area lights and transform{}? Server Time
13 Oct 2025 21:07:48 EDT (-0400)
  Problem with area lights and transform{}? (Message 1 to 10 of 12)
Subject: Problem with area lights and transform{}?
Date: 3 May 2007 05:40:02
Message: <web.4639ad4565c782bbc717c9af0@news.povray.org>
Hi Folks,
I was playing with a macro to create area lights and hit a snag. One of the
parameters was a transform{} block to position the light and this seems to
be working wrong.
After some tinkering I came up with a fairly minimal scene that shows the
problem on my system, in that using a rotate and translate either directly
or in a transform{} block give different results in the Windows version of
3.6.1c.
Can someone confirm the problem or point out what I'm doing wrong? I find it
hard to believe that it is a bug in such a well used part of the code ...
Thanks,
Mike Andrews.
// --- Start of areaLightTransform.pov ---
// +w640 +h480 +a0.1
// Change useTransform to 'on' to see problem
#declare useTransform = off;
global_settings {
  assumed_gamma 1.0
  max_trace_level 50
  ambient_light 1
 up <0, 1, 0>
 location  <-1, 15, -25>
 angle     10
 look_at   0
plane {
  y, 0
  pigment { rgb 1 }
  finish { diffuse 1 ambient 0 brilliance 0.5 }
light_source {
  0, rgb 1
  area_light x,y, 2,2
  #if (useTransform)
    transform {rotate -90*x translate <0,2,0>}
  #else
#declare tBlack = texture {
  pigment { rgb 0 }
  finish { diffuse 0 ambient 0 }
cylinder { -y,0.3*y,0.02 translate < 0,0,-1> texture {tBlack} }
cylinder { -y,0.3*y,0.02 translate <-1,0,0>  texture {tBlack} }
cylinder { -y,0.3*y,0.02 translate < 0,0,0>  texture {tBlack} }
cylinder { -y,0.3*y,0.02 translate < 1,0,0>  texture {tBlack} }
cylinder { -y,0.3*y,0.02 translate < 0,0,1>  texture {tBlack} }
// --- End of areaLightTransform.pov ---
Subject: Re: Problem with area lights and transform{}?
Date: 3 May 2007 09:43:39
Message: <4639e70b@news.povray.org>
I can't know the exact reason for this, but this is my educated guess:
  A 'transform' identifier probably uses internally a transformation
matrix, and when you apply a matrix transformation to the light, the area
light ignores it because the transformation matrix might transform it in
ways which make it invalid (ie. not rectangular). Direct 'translate' and
'rotate' commands are "optimized" so that they are applied to the area
light appropriately.
  If this is the case, there may be two possible solutions (both of which
require enhancing the source code of povray):
  1) When applying a matrix transfomration to the area light, check if it
will keep the area light rectangular, and if so, apply it, else don't (and
issue a warning).
  2) Enhance the 'transform' identifier so that it internally knows what
types of transforms have been added to it, so these can be easily checked
or applied separately as needed.
Date: 3 May 2007 11:15:01
Message: <web.4639fb211a0c1e53c717c9af0@news.povray.org>
Hi Warp,
Thanks for the reply.
I just tested your theory by adding a matrix<> block the light, both inside
and out of the transform as before. I used
      matrix < 1.5, 0,-0.25,
               0.5, 1,    0,
                 0, 0,    1,
                 0, 0,    0>
before the scale and rotate, which is a shear/scale/rotate mix, and the
light seems to cope with this fine outside of the transform{} block.
Can anyone tell me where in the source code a light_source actually applies
a transform block? I tried following through from 'parse.cpp' where
Transform_Object ((OBJECT *)Object, Parse_Transform(&Local_Trans));
is called. This is defined in 'objects.cpp' where
Transform(Object,Trans);
is called. Transform() is a macro declared in 'frame.h' as
#define Transform(x,y) ((*((x)->Methods->Transform_Method)) (x,y))
but I can not figure out where Transform_Method() is declared for a
light_source object ...
Any other thoughts welcomed,
Mike Andrews.
> issue a warning).
Date: 3 May 2007 12:19:30
Message: <pan.2007.05.03.16.19.24.286679@removeit.geloescht.net>
> applies a transform block? I tried following through from 'parse.cpp'
> where
Take a look at point.cpp. It seems that Transform_Light_Source() actually
does nothing special with area lights. Only Translate_Light_Source() does
not call Transform_Light_Source() (scale and rotate do), but does it
itself. I don't know how the area light sample points are stored exactly,
but that may be the cause.
Date: 3 May 2007 14:10:01
Message: <web.463a24441a0c1e53c717c9af0@news.povray.org>
Hi Lucas,
Thanks for this, I think you've identified where the problem lies!
The lines
  MTransPoint (Light->Axis1,     Light->Axis1,     Trans);
  MTransPoint (Light->Axis2,     Light->Axis2,     Trans);
should deal with the area_light axes, but I think that they should use the
MTransDirection() function as the spotlight direction item does and not the
MTransPoint() function. I think that these functions differ in that
MTransPoint() incorporates a translate where MTransDirection() does not.
To check this I replaced the 'translate <0,2,0>' in my test code with
      matrix < 0, 0, 0,
               0, 0, 0,
               0, 0, 0,
               0, 2, 0>
and now the code produces identical, incorrect results whether or not a
transform{} block is used!
I think that this needs to be reported as a Bug in the core v3.6 code. I'm
not sure whether it has been carried over to v3.7 as that's timed out on my
PC.
Well, problem solved I think. Thanks those who have thought about this. Can
anyone think of a work around or is it a show-stopper for what I was trying
to achieve?
Mike Andrews.
> > where
[snip]
Date: 3 May 2007 15:20:01
Message: <web.463a353e1a0c1e53773c9a3e0@news.povray.org>
"Mike Andrews" <nomail@nomail> wrote:
> Can anyone think of a work around or is it a show-stopper for what I was trying
> to achieve?
If your intention is to have something like:
#declare tr1 = transform {rotate -90*x translate <0,2,0>}
light_source { foo transform { tr1 } }
Then you can accomplish the same by using a macro rather than a declare:
#macro tr1() rotate -90*x translate <0,2,0> #end
light_source { foo tr1()  }
It's even shorter and reuses previous values just like in a declare. :)
Of course, a general matrix transform won't work while the bug isn't
corrected...
Date: 3 May 2007 15:40:01
Message: <web.463a39e31a0c1e53866e560d0@news.povray.org>
Hi nemesis,
I'm writing a macro of the form
areaLight(_Colour,_Size,_subPanels,_Lights,_Transform)
that creates a visible light panel with the required characteristics.
I've actually figured out a generic work around given a declared transform.
Using vtransform from 'transforms.inc' you can split the translate out as
follows:
    #local _Translate = vtransform(x*0,_Transform);
    transform {_Transform translate -_Translate}
    translate _Translate
So I can finish writing the macro now :-)
Bye for now,
Mike Andrews.
> > to achieve?
> corrected...
Date: 3 May 2007 17:55:54
Message: <463a5a6a@news.povray.org>
Mike Andrews nous apporta ses lumieres en ce 03-05-2007 05:37:
> Hi Folks,
> be working wrong.
> 3.6.1c.
> Thanks,
> Mike Andrews.
> global_settings {
>   assumed_gamma 1.0
>   max_trace_level 50
>   ambient_light 1
> camera {
>  up <0, 1, 0>
>  angle     10
>  look_at   0
> plane {
>   y, 0
>   pigment { rgb 1 }
> light_source {
>   0, rgb 1
>   area_light x,y, 2,2
>   #if (useTransform)
>   #else
>   #end
>   pigment { rgb 0 }
The transform aparently translate THEN rotate.
When you rotate your area_light, it stay in place but the plane of the aray does
rotate and become horizontal, you then you translate it 2 unit straight up.
I can read your mind, and you should be ashamed of yourself.
Date: 4 May 2007 02:14:20
Message: <463acf3c@news.povray.org>
Mike Andrews schrieb:
> Hi Lucas,
> The lines
I have not checked the code myself but if these this is the way area
lights are transformed this is indeed wrong.  You should post a bug report.
-- Christoph
Date: 4 May 2007 07:00:01
Message: <web.463b118f1a0c1e53c717c9af0@news.povray.org>
Hi Christoph,
Thanks, it's good to know that someone else thinks this is the problem code.
I've submitted a bug report to povray.bugreports, so we'll have to wait to
see if it gets past the moderator :-)
Bye for now,
Mike Andrews.
> > Hi Lucas,
> > The lines
> -- Christoph
