POV-Ray : Newsgroups : povray.general : radiosity and normals Server Time
26 Dec 2025 20:36:23 EST (-0500)
  radiosity and normals (Message 1 to 6 of 6)
Subject: radiosity and normals
Date: 4 Apr 2007 09:30:01
Message: <web.4613a7ea7cfdeec4be7bfb550@news.povray.org>
I have a question which probably has been already answered. If so, sorry.
The question is: when something it's being illuminated only with radiosity,
normal effect disappear. That is my experience. Is there a way to solve
this without adding real lights?. Thanks.
Subject: Re: radiosity and normals
Date: 4 Apr 2007 10:12:38
Message: <4613b255@news.povray.org>
  Apparently you have not experimented by adding "normal on" inside the
radiosity block.
Date: 4 Apr 2007 10:55:01
Message: <web.4613bbbbf164c865be7bfb550@news.povray.org>
> radiosity block.
Yes I didn't, thanks for the information. I'll try and then I'll tell you.
Date: 4 Apr 2007 15:24:34
Message: <4613fb72$1@news.povray.org>
kike nous apporta ses lumieres en ce 04-04-2007 10:52:
>> radiosity block.
>>                                                           - Warp
Be warned that adding normal on will make the render takes more time, possibly a
lot more.
Idolism: Let's bronze this shit.
Date: 5 Apr 2007 13:33:34
Message: <461532ee@news.povray.org>
"kike" <dry### [at] hotmailcom> wrote in message
news:web.4613bbbbf164c865be7bfb550@news.povray.org...
If you haven't gone through the "radiosity tutorial" in the manual, it's a
great reference for what the radiosity settings do (section 2.3.7).  It
makes more sense to me than simply reading the actual manual section on
Radiosity.  I'm constant referring to it, though I still generally end up
only tweaking "count" and "error_bound".
Date: 6 Apr 2007 06:50:02
Message: <web.46162588f164c865519bbb570@news.povray.org>
Well, I actually read it long ago but it seemed to be a bit useless, let me
explain. As far as I read, in summary the conclusion of that tutorial was
"there are two or three obvios parameters, for the rest of them, explore
yourself the results when changing them".
But in this particular case I recognize my error. When I found the problem I
should have taken a look again to the tutorial.
