POV-Ray : Newsgroups : povray.general : "Identifier expected, incomplete function call or spline call found instead= Server Time
13 Jan 2025 09:37:04 EST (-0500)
  "Identifier expected, incomplete function call or spline call found instead= (Message 1 to 1 of 1)
Subject: "Identifier expected, incomplete function call or spline call found instead=
Date: 12 Jan 2007 19:05:01
Message: <web.45a8217efdabbdc39356f54f0@news.povray.org>
It sounds like this is a known bug, fixed in 3.7 but ever so nagging in 3.6.
I haven't been able to re-produce it in 3.7 like I thought I had done
before, which is consistent with Thorsten's comment that it's been fixed in
3.7.  I must've gotten mixed up when I was going back & forth between 3.6 &
3.7 when I was tired :-)
I sometimes get an error message "Identifier expected, incomplete function
call or spline call found instead" in places where there are references to
spline identifiers without parenthesis, such as  a #declaring one spline
identifier = another spline identifier, or when passing a spline as a macro
parameter.
Here are links to related recent posts:
See comment at bottom:
http://news.povray.org/povray.general/thread/%3Cweb.45a68007797c8d649356f54f0%40news.povray.org%3E/
Here's where I was trying to figure out what was happening without a
compiler to debug with:
http://news.povray.org/povray.programming/thread/%3Cweb.45a757f351b89e832f60260%40news.povray.org%3E/
Here's an attempt at making a scene minimal while demonstrating the error in
multiple ways:
And here's the inline code which you will likely get un-formated... which is
why I posted the file:
Charles
PS, This scene isn't intended to be interesting to look at when rendered.
Just try different quantities of pluses & minuses in the "bug avoidance"
block with & without the counter incrementing line in the loop commented
out.  The scene does look a bit interesting with a few modifications though
//Takes in an array of 4D vectors where x, y, & z are world coordinates
//as you'd expect and t represents the value-along-spline for the given
//control point.  Returns a transformed array still suitable for turning
//into a spline.  Order of rotation matches that of spine-macros.
#macro
Transform_Array(TheArray,TheArrayLength,TheScale,TheRotation,TheTranslation)
       #local Ctr = 0;
       #local tempArray = TheArray;
       #while(Ctr < TheArrayLength)
          #local tempVector =
<tempArray[Ctr].x,tempArray[Ctr].y,tempArray[Ctr].z> * TheScale;
          #local tempVector = vrotate(tempVector, <TheRotation.x,0,0>);
          #local tempVector = vrotate(tempVector, <0,0,TheRotation.z>);
          #local tempVector = vrotate(tempVector, <0,TheRotation.y,0>);
          #local tempVector = tempVector + TheTranslation;
          #local tempArray[Ctr] =
<tempVector.x,tempVector.y,tempVector.z,tempArray[Ctr].t>;
          #local Ctr = Ctr + 1;
       #end  //end while
       tempArray //returned value
#end  //end macro Transform_Array()
//Like Transform_Array() but order is !IN REVERSE!
#macro
Transform_Array_In_Reverse(TheArray,TheArrayLength,TheScale,TheRotation,TheTranslation)
       #local Ctr = 0;
          #local tempVector =
<tempArray[Ctr].x,tempArray[Ctr].y,tempArray[Ctr].z>;
          #local tempVector = tempVector * TheScale;
       #end  //end while
#end  //end macro Transform_Array_In_Reverse()
//control point.  Returns a spline.
#macro Spline_From_Array (The_Array, Array_Length )
  #declare TempSpline = spline{
   cubic_spline
   #local ctr = 0;
   #while (ctr < Array_Length)
      #local tempfloat = The_Array[ctr].t;
      //tempfloat avoids a type-error iirc
      tempfloat,  <The_Array[ctr].x, The_Array[ctr].y, The_Array[ctr].z>,
      #local ctr = ctr+1;
   #end //end while
   //Note that the last value has an extra comma at the end.
   //That could be fixed with an #if statement but is it a problem?
  } //end spline
  TempSpline
#end //end #macro Spline_From_Array()
//It's an analogy.  a_posi is to the range a_low to a_high
//what RESULT is to the range b_low to b_high.
//E.g. Range_Convert(25,0,100,32,212) returns: 77 (degrees F)
//E.g. Range_Convert(77,32,212,0,100) returns: 25 (degrees C)
#macro Range_Convert(a_posi, a_low, a_high, b_low, b_high)
      (   ( (a_posi-a_low)*(b_high-b_low)/(a_high-a_low) ) + b_low    )
#end // end macro Range_Convert()
//It's pretty straight foward:
#macro
Plot_Spline2(TheSpline,Plot_Min_Val,Plot_Max_Val,Thickness,Frequency,Color1,Color2)
   union{
    #local ctr = Plot_Min_Val;
    #while (ctr < Plot_Max_Val)
      sphere {
        TheSpline(ctr),Thickness
        pigment {rgb
Color1*(Range_Convert(ctr,Plot_Min_Val,Plot_Max_Val,1,0))
+Color2*(Range_Convert(ctr,Plot_Min_Val,Plot_Max_Val,0,1))
                //{ rgb <1-ctr,ctr,0> }
        finish {ambient 1 }
      #local ctr = ctr + Frequency;
    #end //end while
   } //end union
#local XZ_Circle_Radius = 1;
//Maybe next time I'll just use fractions of pi.
#declare XZ_Circle_Array =
array[19]{
<sin(radians(-112.5))*XZ_Circle_Radius,0,cos(radians(-112.5))*XZ_Circle_Radius,
-.125/2> //tangent
<sin(radians(   -90))*XZ_Circle_Radius,0,cos(radians(
-90))*XZ_Circle_Radius,  .0  /2> //start
<sin(radians( -67.5))*XZ_Circle_Radius,0,cos(radians(
-67.5))*XZ_Circle_Radius,  .125/2>
<sin(radians(   -45))*XZ_Circle_Radius,0,cos(radians(
-45))*XZ_Circle_Radius,  .25 /2>
<sin(radians( -22.5))*XZ_Circle_Radius,0,cos(radians(
-22.5))*XZ_Circle_Radius,  .375/2>
<sin(radians(     0))*XZ_Circle_Radius,0,cos(radians(
0))*XZ_Circle_Radius,  .5  /2>
<sin(radians(  22.5))*XZ_Circle_Radius,0,cos(radians(
22.5))*XZ_Circle_Radius,  .625/2>
<sin(radians(    45))*XZ_Circle_Radius,0,cos(radians(
45))*XZ_Circle_Radius,  .75 /2>
<sin(radians(  67.5))*XZ_Circle_Radius,0,cos(radians(
67.5))*XZ_Circle_Radius,  .875/2>
<sin(radians(    90))*XZ_Circle_Radius,0,cos(radians(
90))*XZ_Circle_Radius, 1.0  /2>  //middle
<sin(radians( 112.5))*XZ_Circle_Radius,0,cos(radians(
112.5))*XZ_Circle_Radius, 1.125/2>
<sin(radians(   135))*XZ_Circle_Radius,0,cos(radians(
135))*XZ_Circle_Radius, 1.25 /2>
<sin(radians( 157.5))*XZ_Circle_Radius,0,cos(radians(
157.5))*XZ_Circle_Radius, 1.375/2>
<sin(radians(   180))*XZ_Circle_Radius,0,cos(radians(
180))*XZ_Circle_Radius, 1.5  /2>
<sin(radians( 202.5))*XZ_Circle_Radius,0,cos(radians(
202.5))*XZ_Circle_Radius, 1.625/2>
<sin(radians(   225))*XZ_Circle_Radius,0,cos(radians(
225))*XZ_Circle_Radius, 1.75 /2>
<sin(radians( 247.5))*XZ_Circle_Radius,0,cos(radians(
247.5))*XZ_Circle_Radius, 1.875/2>
<sin(radians(   270))*XZ_Circle_Radius,0,cos(radians(
270))*XZ_Circle_Radius, 2.0  /2>  //end
<sin(radians( 292.5))*XZ_Circle_Radius,0,cos(radians(
292.5))*XZ_Circle_Radius, 2.125/2>  //tangent
} // end array XZ_Circle_Array
//I think the problem is dependent related to the value of token_count.
//For the following list of 21 #declare statements, the use of extra "+"
//and/or "-" symbols affects where whether the error occurs on line ...
//or on line ....  If the total number of extra symbols is divisible by
//3 in the case of this block, the error occurs on line ..., otherwise
//it occurs on line ...  Try it. Try moving them.  It doesn't matter where
//they go.
//3 or 7 extra + or - symbols will cause it to fail even if infinate loop
//below is changed to finite.
#declare dummy_var = +1;//bug avoidance 1
#declare dummy_var = +1;//bug avoidance 2
#declare dummy_var = +1;//bug avoidance 3
#declare dummy_var = -1;//bug avoidance 4
#declare dummy_var = 1;//bug avoidance 5
#declare dummy_var = -1;//bug avoidance 6
#declare dummy_var = -1;//bug avoidance 7
#declare dummy_var = 1;//bug avoidance 8
#declare dummy_var = 1;//bug avoidance 9
#declare dummy_var = 1;//bug avoidance 10
#declare dummy_var = 1;//bug avoidance 11
#declare dummy_var = 1;//bug avoidance 12
#declare dummy_var = 1;//bug avoidance 13
#declare dummy_var = 1;//bug avoidance 14
#declare dummy_var = 1;//bug avoidance 15
#declare dummy_var = 1;//bug avoidance 16
#declare dummy_var = 1;//bug avoidance 17
#declare dummy_var = 1;//bug avoidance 18
#declare dummy_var = 1;//bug avoidance 19
#declare dummy_var = 1;//bug avoidance 20
#declare dummy_var = 1;//bug avoidance 21
// Again, the failure point depends on how many added tokens there
// are in the above block...
//  # (of "-" anywhere in the list.)
//  1 fails at Plot_Spline2(...)
//  2 fails at Plot_Spline2(...)
//  3 fails at #local Spline_A = Spline_From_Array(Array_A,19);
//  4 fails at Plot_Spline2(...)
//  5 fails at Plot_Spline2(...)
//  6 fails at #local Spline_A = Spline_From_Array(Array_A,19);
//  7 fails at Plot_Spline2(...)
//  8 fails at Plot_Spline2(...)
//  9 fails at #local Spline_A = Spline_From_Array(Array_A,19);
// 10 fails at Plot_Spline2(...)
// 11 fails at Plot_Spline2(...)
// 12 fails at #local Spline_A = Spline_From_Array(Array_A,19);
// 13 fails at Plot_Spline2(...)
// 14 fails at Plot_Spline2(...)
// 15 fails at #local Spline_A = Spline_From_Array(Array_A,19);
// 16 fails at Plot_Spline2(...)
// 17 fails at Plot_Spline2(...)
// 18 fails at #local Spline_A = Spline_From_Array(Array_A,19);
// 19 fails at Plot_Spline2(...)
// 20 fails at Plot_Spline2(...)
// 21 fails at #local Spline_A = Spline_From_Array(Array_A,19);
#local M_Rand = seed(0);
#local Itr_Ctr = 0;
#while(Itr_Ctr < 40)
  #local Some_Scale = <rand(M_Rand),rand(M_Rand)rand(M_Rand)>/10;
  #local Some_Rot   = <rand(M_Rand),rand(M_Rand)rand(M_Rand)>*360;
  #local Some_Tran  = <rand(M_Rand),rand(M_Rand)rand(M_Rand)>*1;
  #local Some_Thk   = rand(M_Rand)/9;
  #local Some_Clr_1 = <rand(M_Rand),rand(M_Rand)rand(M_Rand)>;
  #local Some_Clr_2 = <rand(M_Rand),rand(M_Rand)rand(M_Rand)>;
  #local Some_Freq  = .05;//rand(M_Rand)/10;
  //#if(Some_Freq < .01) #local Some_Freq = .01; #end
  //Too many spheres don't help show the problem.
  //usage:
  #local Array_A =
Transform_Array(XZ_Circle_Array,19,Some_Scale,Some_Rot,Some_Tran);
  //usage: Spline_From_Array (The_Array, Array_Length)
  //usage:
  Plot_Spline2(Spline_A,0,1,Some_Thk,Some_Freq,Some_Clr_1,Some_Clr_2)
    //Infinite loop is by default.  Un-comment it to have a chance at
rendering.
    //If un-commented it will render if the "bug avoidance" block above
contains
    //anything other than exactly 3 or 7 "-" or "+" symbols aka extra
tokens.
  //#local Itr_Ctr = Itr_Ctr+1;
#end //end #while
