POV-Ray : Newsgroups : povray.general : is there any feature for volume raytracing with povray? Server Time
27 Feb 2026 21:03:41 EST (-0500)
  is there any feature for volume raytracing with povray? (Message 1 to 10 of 16)
Subject: is there any feature for volume raytracing with povray?
Date: 10 Jan 2007 03:35:00
Message: <web.45a4a43af46d0e7d1524ae1d0@news.povray.org>
In fact, I want to render the implicit iso-surface embeded in 3D volume data
set.
if there is no such feature in Povray, how about some other? such as
MegaRay, ...
thanks~
Subject: Re: is there any feature for volume raytracing with povray?
Date: 10 Jan 2007 03:36:21
Message: <45a4a585@news.povray.org>
> set.
  Could you explain what that means?
Date: 10 Jan 2007 04:10:00
Message: <web.45a4acdfaa1909d1524ae1d0@news.povray.org>
> > set.
Oh, maybe my description is not so clear.
what i want is the volume raytracing technique based feature in povray.
I know that we can render the implicit iso-surface by using the existing
keyword "isosurface" in povray, but it seems that it is based on some
technique like Marching Cube, which first extraction the geometry of the
iso-surface. But with volume raytracing technique, we can directly raytrace
the volume data and save the geometry extracting step.
who can tell me something about it? does any xx-ray can do such things
exists?
thanks
Date: 10 Jan 2007 04:42:41
Message: <45a4b511$1@news.povray.org>
>>> set.
>>                                                           - Warp
As far as I understand there is no extraction of geometry in POV-Ray's
isosurfaces, it indeed uses what you call "volume raytracing". In other
words, for each ray the intersection with the surface is computed, but
the surface is not reconstructed as a whole.
Regards
Vincent
Date: 10 Jan 2007 06:51:17
Message: <45a4d335$1@news.povray.org>
> raytrace
Look up df3 files and media in the POV docs, it might do what you want
(never used it myself).
Date: 10 Jan 2007 09:40:09
Message: <45a4fac8@news.povray.org>
  Isosurfaces don't use anything like marching cubes, and I don't really
understand what is the relation between isosurfaces and volume raytracing.
Date: 10 Jan 2007 12:52:50
Message: <45a527f2$1@news.povray.org>
Volume data from medical imaging techniques measures densities. Everything
else you see, i.e. specific organs, is the result of clever post processing
in conjunction with contrast enhancing substances the human received. Thus,
if you want to extract specific information you can use isosurfaces by
defining their threshold to the desired density.
Regarding the original post, to use the data, it has to be converted to a
POV-Ray density file. This file can then be turned into a pattern, which can
be used in an isosurface for rendering. In fact, the original isosurface
patch website (iirc that page is no longer available) had a sample image of
a human head.
	Thorsten
Date: 10 Jan 2007 13:49:12
Message: <Xns98B4C99E05131seed7@news.povray.org>
> volume data set.
You can render an isosurface from a data set as Thorsten mentioned, you
can also use this data set with media. An old image that uses both
techniques:
Newsgroups: povray.binaries.images
Subject: frog
Message-ID: <8FC995A5Cseed7@204.213.191.228>
Date: 10 Oct 2000 09:27:46 -0400
Xref: news.povray.org povray.binaries.images:41670
http://news.povray.org/povray.binaries.images/attachment/%
3C8FC995A5Cseed7%40204.213.191.228%3E/frog.jpg
Ingo
Date: 16 Jan 2007 01:40:00
Message: <web.45ac71aaaa1909d1524ae1d0@news.povray.org>
Many thanks for your interests, everyone. Sorry, am pretty busy these days.
I uploaded an image to povray.binaries.images,
http://news.povray.org/povray.binaries.images/thread/%3Cweb.45ac7028a8a7f8c81524ae1d0%40news.povray.org%3E/.
the image was rendered by using the isosurface object just like Thorsten
described.
to Vincent:
Am not sure how does povray implement the feature of "isosurface", if it
really does as what you said, that is exactly what I need. I was told that
this is also a kind of volume raytracing technique by a friend, but am not
sure. However, from the figure I uploaded, we can see patches, so I guess
that maybe povray firstly extracts the implicit surface geometry with some
tessellation technique. But this is just a guess. Another possibility is
that indeed it does with the method you said, but the normal for each
intersection is computed not so good by povray, so that the surface looks
not so smooth and appears like patches.
to Warp:
Sorry for my unclear description. According to my current limited knowledge,
the scattering, emission and absorption media are the typical feature of
volume raytracing technique, but do you think the method described by
Vincent is also a kind volume raytracing technique?
to Ingo:
Thanks for your image. I guess the white islands on the frog's skin are the
results of isosurface, am I right? :). But the image's resolution is not
large enough to determine whether there are quad patches or not.
to Thorsten:
Can you give me some comments towards the patches in my image? In fact, I
want to get a smooth surface from the volume data set. Maybe I used the
isosurface object incorrectly. the code for the isosurface object is:
#declare dens=function{pattern {density_file df3 densityfile interpolate 1}}
#declare interface=object{
  isosurface{
    function{dens(x,y,z)}
    threshold iso_value
    contained_by { box { 0.03, 0.97 } }
    open
  pigment{rgbt <1., 1., 0.1, 0.5>}
  finish{
    ambient  0.3
    diffuse  0.3
    roughness 0.5
    brilliance 1
  scale 1.06
  translate -0.03
The resolution for the volume data I used is 32x32x32, but i think finer
data can only alleviate the problem to some degree. Yet, I should try finer
data...
Date: 16 Jan 2007 14:24:37
Message: <45ad2675$1@news.povray.org>
lien0n nous apporta ses lumieres en ce 16-01-2007 01:36:
> described.
> to Vincent:
> to Warp:
> to Ingo:
> to Thorsten:
>   isosurface{
>     threshold iso_value
>     open
>   finish{
>     ambient  0.3
>     diffuse  0.3
>     roughness 0.5
>     brilliance 1
>   scale 1.06
>   translate -0.03
> data...
In a DF3 file, each value apply to a cube, so, you obviously get a blocky aspect.
POV-Ray don't use any tessellation. It samples along a ray and evaluate the
isosurface value at a point, if it evaluate to less than the therhold, you are
outside the object, it it evaluate at the threshold, you are ON the surface, if
larger, then you are inside.
DF3's are mostly used for media dencity where the blockyness is less visible.
The strongest reason for the people to retain the right to keep and bear
arms is, as a last resort, to protect themselves against tyranny in
government.
Thomas Jefferson
