POV-Ray : Newsgroups : povray.general : Spherical Sweep Along a Parametric Curve Server Time
19 Mar 2026 09:39:28 EDT (-0400)
  Spherical Sweep Along a Parametric Curve (Message 1 to 3 of 3)
Subject: Spherical Sweep Along a Parametric Curve
Date: 25 Nov 2006 02:25:00
Message: <web.4567ebe377f8a7548c37caaf0@news.povray.org>
Specific:
I recently needed to create an elliptical cylinder with a rounded (circular)
edge.  To do this, I wrote the following macro for generating a parametric
surface which I call a "torlipse" (from "torus" and "ellipse").  The
torlipse is a spherical sweep of radius 'r' along the parameterized ellipse
e(u) = < a * cos(u), 0, b * sin(u) >.
//  Last updated: 2006.11.24
//  Description: Macro which generates a spherical sweep of
//  radius 'r' along an ellipse in the x-z plane with
//  semi-radii of 'a' and 'b'. The parameters 'th0' and
//  'th1' allow the possibility of a sweep along an elliptical
//  arc.  Use th0 = 0 and th1 = 2*pi for a complete sweep.
#macro torlipse( a, b, r, th0, th1 )
    parametric {
        function { cos(u) * ( a + cos(v)*r*b / sqrt( pow(b*cos(u), 2) +
pow(a*sin(u), 2) ) ) },
        function { -r*sin(v) },
        function { sin(u) * ( b + cos(v)*r*a / sqrt( pow(b*cos(u), 2) +
        <th0, 0>, <th1, 2*pi>
        contained_by { box { 1.1 * <-a-r, -r, -b-r>, 1.1 * <a+r, r, b+r> } }
        precompute 10 x,y,z
        accuracy 0.000001*r
To no avail, as of yet, I continue to determine the possibility of
expressing this surface as an isosurface.
General:
I see the potential need to render a spherical sweep along any
parameterizable curve in 3-space.  I cannot imagine that I am the first to
address this need.
So, my questions to the POVRay community are
    1)  Has someone already established a good generalized method for
rendering spherical sweeps along parameterizable curves?
    2)  Is it possible to express a spherical sweep along any
parameterizable curve into an isosurface expression? (Obviously, it is
possible for special cases: e.g. line segment -> cylinder and circle ->
torus.)
    3)  Would it be beneficial to include a built-in function for creating
spherical sweeps along parametric curves in future releases of POV
Raytracer?
If someone else has already done the work, then I would like to save myself
the time and effort.  On the other hand, if it turns out that this is a new
or pending 'todo', then I wish to contribute my efforts to the POVRay
community.
I will appreciate any response.
Yours,
Randall Sawyer
Subject: Re: Spherical Sweep Along a Parametric Curve
Date: 25 Nov 2006 06:43:17
Message: <qVd5KOAhoCaFFwau@econym.demon.co.uk>
Have you considered using a sphere_sweep?
#declare A=2;
#declare B=1.5;
#declare R=0.2;
#declare fx = function(x) { A*sin(x)}
#declare fy = function(y) {0}
#declare fz = function(z) { B*cos(z)}
#declare Steps = 20;
sphere_sweep {
  b_spline
  Steps+3,
  #local i=0;
  #while (i<Steps+3)
    #local a = 2*pi*i/Steps;
    <fx(a), fy(a), fz(a)>, R
    #local i=i+1;
  //tolerance 1.0e-4
  pigment {rgb <1,1,0>}
If you use a high value for Steps then you may need to use a tollerance
setting to avoid ugly artefacts.
The "Steps+3" bit allows for the additional control points required for
b_spline or cubic_spline so that you get a closed loop. If using
linear_spline then you only need Steps+1, but you also need a very high
value of Steps to make it look smooth, and then you get awful artefacts
that can't be got rid of by setting tolerance.
Mike Williams
Gentleman of Leisure
Date: 25 Nov 2006 16:10:00
Message: <web.4568b07cd669f4188c37caaf0@news.povray.org>
Thank you.  That works well.
With a background in mathematics, I was looking for an explicit solution
based on differential geometry.  But, I must concede that in a pixelized
environment, approximations such as splines work just fine.
Your solution renders a lot faster too.
-Randall
