![](/i/fill.gif) |
Im making an airport for an assignment.
This is the first time I have used POVray and I am quiet inexperienced.
I have just made a box which will represent a terminal building, see code:
//terminal
box {
<-106, -50, -50>,
<106, 50, 50>
transform
{ rotate< 0,-85,0> translate<-310,0,220>}
pigment { color Gray65 }
I then want to place some text on the front of the terminal building with a
name of the airport but as my airport terminal is rotated slightly because
of the whole airport im having trouble making the text sit directly onto
the building, text code:
text{ttf "arial.ttf", "Ell's Airport",1, 0
texture{ pigment{color rgb<1,0.7,0.2>}
finish{ambient 0.65 diffuse 0.55 phong 1 reflection 0.2}}
rotate<90,-90,-90> scale<5,22,14,> translate<-255,35,190> }
Here is an image of what it looks like at the moment - you will see the
problem:
http://img489.imageshack.us/img489/7508/airportza1.jpg
As you can see the E sticks out more than the t but it seems that any
rotation that I try it dosent seem to make any difference.
Thanks for any help!
![](/i/fill.gif) |
![](/i/fill.gif) |
Your terminal is rotated 85 degrees.
Your text is rotated 90 degrees.
That's the fundamental problem, I expect. Try rotating both Y amounts
the same.
"That's pretty. Where is it?"
"Channelwood."
"We should go there on vacation."
![](/i/fill.gif) |
