POV-Ray : Newsgroups : povray.general : From a normal to an angle? Server Time
30 Sep 2024 07:21:36 EDT (-0400)
  From a normal to an angle? (Message 1 to 8 of 8)
Subject: From a normal to an angle?
Date: 19 Aug 2006 16:45:00
Message: <web.44e77810987acea1e921dc270@news.povray.org>
How do I convert a nomal generated by the trace function to an angle in
degrees? I am trying to determine the final transformation....here is the
code I am using:
I am trying to determine the location and rotation of the object after it is
place on the ship's deck.
Tim
Subject: Re: From a normal to an angle?
Date: 19 Aug 2006 17:05:01
Message: <web.44e77cee2c8bed1ce921dc270@news.povray.org>
I forgot the code...oops!
                #declare Target =
                        object {NiagaraHull_1C_
                              scale 330
                              rotate<0,-90,0>
                              translate<1000,-1000,00>
                #declare Norm = <0, 0, 0>;
                #declare Start = <-3496,5000,0>;
                #declare Inter =trace ( Target, Start, <0, -1, 0>, Norm );
                object{MainFifeRail Reorient_Trans(<0,1,0>,  Norm) translate
Inter}
Date: 19 Aug 2006 18:10:10
Message: <44e78c42@news.povray.org>
"Tim McMurdo" <jod### [at] wohrrcom> wrote in message
news:web.44e77cee2c8bed1ce921dc270@news.povray.org...
>                #declare Target =
>                              scale 330
>                              rotate<0,-90,0>
> translate
> Inter}
Hi Tim,
I'd recommend doing it in two parts, so you get the rotation in x followed
by the rotation in z.
For the z rotation you need the angle between the x,y components of the
Normal and the y axis:
#local Z_Rotation =  VAngleD(Norm*<1,1,0>,y);
Now you can rotate the Normal back to the z-y plane then work out the x
rotation:
#local X_Rotation = VAngleD(vrotate(Norm, -Z_Rotation*z),y);
I 've included a little test script that you may find handy below (VAngleD
is in math.inc).
The last two lines rotate a vector of the same length back into position and
write the position into the message stream, so it should always be the same
as the vector you start with.
#include "Math.inc"
//#local Norm = <1,2,3>;
//#local Norm = <-1,2,-3>;
#local Norm = <-8,2,4>;
#local Test = vrotate(y*vlength(Norm),<X_Rotation,0,Z_Rotation>);
#debug concat(vstr(3,Norm,",",3,3),"\n")
Chris B.
Date: 19 Aug 2006 18:16:56
Message: <44e78dd8@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:44e78c42@news.povray.org...
>>                #declare Target =
>>                              scale 330
>>                              rotate<0,-90,0>
>> translate
>> Inter}
> Hi Tim,
> rotation:
> is in math.inc).
> and write the position into the message stream, so it should always be the
> same as the vector you start with.
> #include "Math.inc"
> Regards,
> Chris B.
Aargh,
Please ignore the above, I realised that I'm testing Norm instead of Test,
so I'd fooled myself into believing I'd got it right.
Chris B.
Date: 19 Aug 2006 18:50:10
Message: <44e795a2$1@news.povray.org>
> Regards,
> Chris B.
Sorry about that, I should have been using VRotationD to pick up the angle
and I'd failed to get the correct sequence of parameters to get the
rotational directions correct. The following should be good to go.
#include "Math.inc"
//#local Norm = <-8,-2,4>;
//#local Norm = vrotate(y,<-46,0,-45>);
#local Z_Rotation = VRotationD(y, Norm*<1,1,0>, z);
#local X_Rotation = VRotationD(y, vrotate(Norm, -Z_Rotation*z), x);
#debug concat(vstr(3,Test,",",3,3),"\n")
Chris B.
Date: 19 Aug 2006 20:30:37
Message: <44e7ad2d@news.povray.org>
  It might be easier to use the functions in transforms.inc. They do all
the hard work for you.
Date: 9 Sep 2006 03:40:01
Message: <web.45026de32c8bed1cee7c01140@news.povray.org>
As Warp says, there are REALLY useful rotators and such in transforms,inc.
......although the descriptions of what they do can be a bit difficult to
understand at first. The one I like to use, for what you're trying to
achieve, is Point_At_Trans. It can take an object made at the origin in the
normal way (y-axis pointing up), and whirl the object's y-axis around to
meet a traced normal. I.e., Point_At_Trans (norm). Great for sticking
spiky things onto heightfields! Place it in your code where you would
put a typical rotate command.
Ken W.
Date: 10 Sep 2006 04:40:00
Message: <web.4503cf212c8bed1cc2d4f2880@news.povray.org>
> Tim
Re-reading your question a day later (with my brain working a bit better), I
see that I misread it. You're trying to find the position and angle of an
already-placed object.
Sorry 'bout that....   :-[
Ken
