POV-Ray : Newsgroups : povray.general : Testing for intersection of two objects Server Time
27 Dec 2025 08:32:54 EST (-0500)
  Testing for intersection of two objects (Message 1 to 10 of 21)
Subject: Testing for intersection of two objects
Date: 24 Jul 2006 15:15:01
Message: <web.44c51bba804fff24aaf01cad0@news.povray.org>
Is there a reasonably simple way in POV-Ray to produce a Boolean value
representing whether or no two objects intersect?  As in...
#if ("object{Thing1} intersects object{Thing2}")
      // STUFF TO DO IF THEY INTERSECT
#else
      // STUFF TO DO IF THEY DON'T INTERSECT
I would very much appreciate if some kind soul could point out the section
of the documentation and/or available resources that deal with this issue.
Thanks in advance.
Mike C.
Subject: Re: Testing for intersection of two objects
Date: 24 Jul 2006 15:38:45
Message: <44c521c5$1@news.povray.org>
"Mike the Elder" <zer### [at] wyanorg> wrote in message
news:web.44c51bba804fff24aaf01cad0@news.povray.org...
> #else
> #end
section
issue.
For some simple objects, this could be done, but most of the time it
would be impossible to do accurately imho :-/
best you can do, is to check if the bounding boxes intersect
cu!
Date: 24 Jul 2006 16:15:00
Message: <web.44c529e1c08fcd85c5588fc70@news.povray.org>
> #else
> #end
> Thanks in advance.
> Mike C.
I was interested in your problem and did a couple of quick tests. Testing
min_extent and max_extent on two spheres known to intersect produced
predictable results. When the spheres did not intersect, the results for
the intersection object were as follows.
min_extent = <-10000000000.000000,-10000000000.000000,-10000000000.000000>
max_extent = <10000000000.000000,10000000000.000000,10000000000.000000>
So it looks like this could be used as a test, although I don't really know
how robust it is.
Abe
Date: 24 Jul 2006 17:20:00
Message: <web.44c53894c08fcd85c150d4c10@news.povray.org>
> #else
> #end
> Thanks in advance.
> Mike C.
Perhaps you can use CSG "intersect{}" and then chack min_extents,
max_extents.
Haver a look at this and see if you can get something to work out of it:
//START
global_settings {
  max_trace_level 15
  ambient_light 1
  adc_bailout 0.0001
  location  <0,3,-5>
  look_at   0
#declare LB=
sphere{0 50 hollow no_image
  texture{pigment{rgb 1} finish{ambient 20}}
light_source{0 rgb 1
  looks_like{LB}
  fade_power 2  fade_distance 300
  translate <0,100,-100>
#declare Obj1=sphere{<0,0,0> 1 pigment{rgb<1,0,0>}}
#declare Obj2=sphere{<-2.5,0,0> 1 pigment{rgb<0,1,0>}}
#declare Obj3=sphere{<1.5,0,0> 1 pigment{rgb<0,0,1>}}
object{Obj1}
object{Obj2}
object{Obj3}
#declare Int12=intersection{object{Obj1}object{Obj2}}
#declare Int13=intersection{object{Obj1}object{Obj3}}
#declare Siz12=vlength(min_extent(Int12)-max_extent(Int12));
#declare Siz13=vlength(min_extent(Int13)-max_extent(Int13));
text {ttf "arial.ttf",str(Siz12,0,3),0.1,0 scale 1/3 translate <-2.5,1.5,0>
pigment{rgb 1}}
text {ttf "arial.ttf",str(Siz13,0,3),0.1,0 scale 1/3 translate <1.5,1.5,0>
pigment{rgb 1}}
//END
-tgq
Date: 24 Jul 2006 17:23:35
Message: <h0qrynASpTxEFw04@econym.demon.co.uk>
>> #else
>> #end
>> Thanks in advance.
>> Mike C.
>how robust it is.
POV calculates the intersection of the bounding boxes (because it can
calculate that) and uses that as the bounding box for the intersection
(which would be next to impossible to calculate in the general case).
If you consider these non-intersecting spheres
intersection {
  sphere {0,1}
  sphere {0,1 translate <1.2,1.2,1.2>}
  pigment {rgb x}
Their bounding boxes do intersect at the corner, like this
intersection {
  box{-1,1}
  box {-1,1 translate <1.2,1.2,1.2>}
  pigment {rgb x}
So that method would be wrong in suggesting that the spheres
intersected.
Mike Williams
Gentleman of Leisure
Date: 24 Jul 2006 18:24:23
Message: <44c54897$1@news.povray.org>
   Don't pay too much attention to the other answers because in the
generic case what you ask is just not possible (not even in theory,
at least not in a reasonable time with perfect accuracy).
   You could use a *really* slow method of sampling points inside the
bounding box of one of the objects and seeing if a point is inside
both objects, but this would be very slow and quite inaccurate (you
could, of course, increase accuracy by taking more samples, but there
would still be a margin of error and the amount of time required
probably grows by the power of 3).
Date: 24 Jul 2006 20:10:01
Message: <web.44c5602fc08fcd85131048ba0@news.povray.org>
> >> #else
> >> #end
> >> Thanks in advance.
> >> Mike C.
> >how robust it is.
> intersection {
>   sphere {0,1}
>   pigment {rgb x}
> intersection {
>   box{-1,1}
>   pigment {rgb x}
> intersected.
> Mike Williams
Ha! An inconvenient exception. I think I'll choose to ignore it.
[retreats into own mental bounding box]
Date: 25 Jul 2006 07:01:35
Message: <44c5fa0f$1@news.povray.org>
well , from what i have see
Povray uses a default value min_extent() of -1 , if the object exists or not
, and use a default value max_extent() of 1 if the object exist or not
then if i use this
#local U=intersection { box {0,1}  box {2,3}}
and
#local U2= object {U scale 1000}
if the object  U doesnt exists then we will always have
[max_entent(U2) - max_entent(U) ].x = 0     and
[max_entent(U2) - max_entent(U) ].y = 0     and
[max_entent(U2) - max_entent(U) ].z = 0
and
[min_entent(U2) - min_entent(U)].x =0 and
In brief ..scaling a non existing object will give the same min_extend value
and max_extend value that the non-scaled object .. if not then the object
always exists ..
news:44c54897$1@news.povray.org...
Date: 25 Jul 2006 08:13:41
Message: <44c60af5@news.povray.org>
"NEWS" <pen### [at] caramailfr> wrote in message
news:44c5fa0f$1@news.povray.org...
> not
> then if i use this
> and
> and
> value
> always exists ..
Fine for boxes only. anything else will test wrong. The corners of two
sphere's bounding boxes could intersect without the sphere's intersecting
each other at all. May be it's possible to test it by using the mathematical
formula for each object instead - I'm not sure.
-Nekar Xenos
"The truth is out there"
Date: 25 Jul 2006 10:15:42
Message: <44c6278e$1@news.povray.org>
i think you must read again ...
i check the bounding  of the intersection ... and not the intersection of 2
bounding ...
news:44c60af5@news.povray.org...
> > not
> > then if i use this
> > and
> > and
> > value
object
> > always exists ..
mathematical
> -Nekar Xenos
