POV-Ray : Newsgroups : povray.general : Strange fog effect in solid transparent sphere Server Time
15 Jan 2025 05:03:09 EST (-0500)
  Strange fog effect in solid transparent sphere (Message 1 to 4 of 4)
Subject: Strange fog effect in solid transparent sphere
Date: 28 Jun 2006 09:10:01
Message: <web.44a27ec165a9bf565cd1c85e0@news.povray.org>
Hi all,
I use white vertical ground fog to simulate depth cue for molecular
visualization. A defined a solid transparent sphere that should not contain
fog, because the hollow statement is outcommented (see below).
But objects within this transparent sphere show strange kind of fog. Instead
of white fog (that should not penetrate the transparent sphere) these
objects have "black" fog (see middle green sphere in expample below).
Is there any explanation for this observation or even better is there any
way to get rid of this black fog inside the trasnsparent sphere?
Thanks and best, Simon
camera {direction<0.0,0.0,  -2.835>
 location <0.0 , 0.0 , 0.0>
 right 1.3333333653*x up y
light_source {
<1000.0001,1000.0001,1450.31260>
color rgb<1.0000,1.0000,1.0000>
plane{z , -4000
pigment{color rgb<1.0000,1.0000,1.0000>}
finish{phong 0 specular 0 diffuse 0 ambient 1.0}}
// set global atmospheric fog effect in the scene.
// at the fog distance, there will be 63% visibility
fog {
 fog_type 2               // 1=constant, 2=ground_fog
 distance 10
 color rgb<1.0000,1.0000,1.0000>  // can also have 'filter' and 'transmit'
 fog_offset -880.00
 fog_alt 0.001
 up <0.0,0.0,1.0>
// three green spheres
#declare tex1 = texture { pigment { rgb <0.001,0.999,0.001> } finish {
diffuse 0.75 ambient 0.28 phong 0.75 phong_size 20.0 specular 0 } }
object {
    sphere {<0,0,-920>,50}
    texture {tex1}
object {
    sphere {<130,0,-920>,50}
    texture {tex1}
object {
    sphere {<-130,0,-920>,50}
    texture {tex1}
// transparent large sphere, solid, should not contain fog
// fully encloses middle green sphere, and partially left
// and right green spheres
#declare tex2 = texture { pigment { rgbt <1,1,1,1> } finish { diffuse 0.0
ambient 0.0 phong 0.0 phong_size 0.0 specular 0 } }
object {
    sphere {<0,0,-800>,140}
    texture {tex2}
    //hollow
Subject: Re: Strange fog effect in solid transparent sphere
Date: 28 Jun 2006 12:22:44
Message: <44a2acd4$1@news.povray.org>
	It looks like it's a bug in at least the 3.5/3.6 series.  You might give
a try to POV-Ray 3.7 beta which gives a different, more expected result -- yet
I'm not sure whether it is completely correct.
	- NC
Date: 28 Jun 2006 12:37:43
Message: <44a2b057$1@news.povray.org>
By the way, note that your script can be simplified; for instance:
> plane{z , -4000
background{color rgb 1}  // unless you need to cast shadows on the background...
> object {
>     texture {tex1}
sphere{<0,0,-920>,50 texture {tex1}}
	- NC
Date: 28 Jun 2006 12:50:00
Message: <web.44a2b22dbfc671cc5cd1c85e0@news.povray.org>
Hi Nicolas, thanks a lot for the 3.7 beta version hint, there I get what I
would expect, the strange black fog is indeed gone!
Best, Simon
