POV-Ray : Newsgroups : povray.general : A difference as a component in a blob? Server Time
19 Mar 2026 06:19:40 EDT (-0400)
  A difference as a component in a blob? (Message 1 to 5 of 5)
Subject: A difference as a component in a blob?
Date: 6 Jun 2006 22:20:01
Message: <web.4486371619dc24e4b9735830@news.povray.org>
here's what i'm trying to do:
 blob {
  threshold .5
  difference{
                sphere {
                        <0, 0, 0>, 1, 1
                        scale <12, 10, 1>
                        translate<0,0,.5>
                cylinder {
                        <9,0,-20>, <9,0,20>, 10, 1
                        scale <1.7,.8,0>
  cone{
       <-2,0,.7>, .6, <5,0,-1.3>, .5, 1
       scale<0,5,.8>
  texture{pigment{color Yellow}}
the problem comes up at the top, right after the 'threshold' line
the error i get says "Need at least one component in a blob" and highlights
the 'difference' line.
any suggestions/solutions?
the end result should look like an elongated crescent with a flat, wide cone
sticking out of the inside of the crescent at an angle.
I've tried declaring the difference bit as its own thing and giving that the
strength modifier instead, but that gives no such luck, either
Subject: Re: A difference as a component in a blob?
Date: 6 Jun 2006 23:35:24
Message: <4486497c@news.povray.org>
>  blob {
>   threshold .5
>   difference{
>                 sphere {
>                         <0, 0, 0>, 1, 1
>                         scale <12, 10, 1>
>                         translate<0,0,.5>
>                 cylinder {
>                         scale <1.7,.8,0>
>   cone{
>        scale<0,5,.8>
As I recall, you can only use spheres and cylinders in a blob.  You can
use a negative strength to achieve the difference.
RG
Date: 7 Jun 2006 00:06:11
Message: <9DYzeAAaBlhEFwVX@econym.demon.co.uk>
> blob {
>  threshold .5
>  difference{
>                sphere {
>                        <0, 0, 0>, 1, 1
>                        scale <12, 10, 1>
>                        translate<0,0,.5>
>                cylinder {
>                        scale <1.7,.8,0>
>  cone{
>       scale<0,5,.8>
Blob doesn't accept the keywords "difference" or "cone".
You can achieve the effect of "difference" by using negative blob
strengths, but you can't blob a cone.
union {
 blob {
  threshold .5
                sphere {
                        <0, 0, 0>, 1, 1
                        scale <12, 10, 1>
                        translate<0,0,.5>
                cylinder {
                        <9,0,-20>, <9,0,20>, 10, -6
                        scale <1.7,.8,0>
  cone{
       scale<0,5,.8> }
Mike Williams
Gentleman of Leisure
Date: 7 Jun 2006 03:39:01
Message: <44868295$1@news.povray.org>
Mike, I'm surprised you didn't bring up your blob like isosurface
example on your isosurface tutorial page:
http://www.econym.demon.co.uk/isotut/combine.htm
Using isosurfaces it would be possible to blob cones, right?
Skip
Date: 7 Jun 2006 10:00:01
Message: <web.4486dbaa1ea405a44b9735830@news.povray.org>
> > blob {
> >  threshold .5
> >  difference{
> >                sphere {
> >                        <0, 0, 0>, 1, 1
> >                        scale <12, 10, 1>
> >                        translate<0,0,.5>
> >                cylinder {
> >                        scale <1.7,.8,0>
> >  cone{
> >       scale<0,5,.8>
> union {
>  blob {
>   threshold .5
>                 sphere {
>                         <0, 0, 0>, 1, 1
>                         scale <12, 10, 1>
>                         translate<0,0,.5>
>                 cylinder {
>                         scale <1.7,.8,0>
>   cone{
>        scale<0,5,.8> }
> Mike Williams
Thanks!
I had no idea you could use negative strengths.
I'll see what i can do about using a cylinder in place of the cone, since
the difference between the ends is only .1 anyway, and it has to blob to
another flattened sphere at the other end anyway
