![](/i/fill.gif) |
We are trying to render a movie in Linux. However, the output window is too
small and when we make the size bigger in windows, the movie loses its
resolution quality. Is there are a way which you might know to make the
output window and the images bigger during the process of rendering so that
we have a better resolution quality?
Thanks in advance
Alp
![](/i/fill.gif) |
![](/i/fill.gif) |
"alpyalcin" <alp### [at] gmail com> wrote in message
news:web.447eb83d14e47cfe957745710@news.povray.org...
> too
> that
> Thanks in advance
> Alp
Hi Alp,
The resolution of the image is controlled using rendering options that can
be set on the command line or in an INI file (or, in the Windows version,
from the pull-down at the top left of the screen).
On the command line you can use +H600 +W800 to set the size to 800x600.
See 'Command-Line Options', 'General Output Options' in the Documentation
for a description of the command line and INI file settings for this.
Chris B.
![](/i/fill.gif) |
![](/i/fill.gif) |
How about reading the documentation which comes with POV-Ray?
Or the online one at povray.org.
![](/i/fill.gif) |
