POV-Ray : Newsgroups : povray.general : Change Color of spheres on a spline while flight Server Time
30 Sep 2024 15:20:39 EDT (-0400)
  Change Color of spheres on a spline while flight (Message 1 to 2 of 2)
Subject: Change Color of spheres on a spline while flight
Date: 17 Feb 2006 15:30:00
Message: <web.43f63134b1f8d7edbd391bf80@news.povray.org>
Hello!
I have a spline with spheres on it and I want the spheres to smoothly change
their color from sphere to sphere between two given colors (start and end
color = start and end of the spline).
I need only the color bit. I work with the 'clock'-Variable.
Thanks!
Chrisir
Subject: Re: Change Color of spheres on a spline while flight
Date: 17 Feb 2006 16:33:02
Message: <43f6410e$1@news.povray.org>
"Chrisir" <nomail@nomail> wrote in message
news:web.43f63134b1f8d7edbd391bf80@news.povray.org...
> Hello!
> change
> Thanks!
> Chrisir
Hi Chrisir,
If you just want to change from one colour to another as the clock variable
changes from 0 to 1, then you can do:
camera {location <0,0,-4> look_at <0,0,0>}
light_source{<3,10,-10> rgb 1}
#declare myColour = Red*clock + Yellow*(1-clock);
sphere {0,1 pigment {color myColour}}
If you render the above with command line options of '+kfi0 +kff10' you
should see the color change.
Because the colors are just vectors you can take a proportion of one and a
proportion of the other and add them together.
For example when the clock is at 0.2 you get 20% Red and 80% Yellow.
Chris B.
