I'm trying to obtain photorealistic renderings of lighting devices using
POV-ray. Our CAD-System is CATIA IV. To exchange these CAD-Data I do the
following steps:
1. Export the CATIA V4 file as IGES.
2. The IGES file can be directly read from RHINOCEROS.
3. RHINOCEROS is able to export directly in POV-ray file format.
4. Read the POV file from POV-ray
In some cases -specially for simple parts- this works properly, but for
complex geometries, POV-ray prompts the following error message :
"No triangles in triangle mesh".
It seems that in some cases "degenerated" triangles are generated by
RHINOCEROS and lead to an error while trying to read the file. In fact,
eliminating the "problematic" code lines makes the POV-file readable, but
of course some parts of the geometry disapear.
AFAIK this bug is already known in the POV community.
Any idea, how can I exchange my CAD data?
Thanks in advance,
Francesc Dorca
"Cesc" <nomail@nomail> wrote:
> Hi,
Can CATIA IV export in the DXF format? If so, then you could use a different
conversion utility like PoseRay to import the file into POV. But whether
or not that would solve the triangles problem is unknown. Worth a try?
Ken
Hi Kenneth,
Thaks for your help, but CATIA can NOT export to DXF.
Cesc
> > Hi,
> Ken
