POV-Ray : Newsgroups : povray.general : Dimensions of Text objects Server Time
15 Jan 2025 16:09:11 EST (-0500)
  Dimensions of Text objects (Message 1 to 2 of 2)
Subject: Dimensions of Text objects
Date: 25 Dec 2005 14:10:01
Message: <web.43aeed721711602cdb1d7b250@news.povray.org>
Is there a way to derive the x and y (width and height) of text objects ? I
would like to know the complete string dimensions.
I am trying to center text on an object and knowing it's width would make
the job easier
Subject: Re: Dimensions of Text objects
Date: 25 Dec 2005 14:20:28
Message: <43aef0fc$1@news.povray.org>
Steaphany Waelder nous apporta ses lumieres en ce 2005-12-25 14:05:
> the job easier
Yes by using max_extent(OBJECT_IDENTIFIER) and min_extent(OBJECT_IDENTIFIER). It works
with any object.
#declare you text object with no rotation, feed it to max_ and min_extent, calculate
the mid point
and translate your object as needed. If you need to rotate it, translate it by half
it's dimention
(to center it around the origin), rotate, then translate to it's final position.
A critic is a man who knows the way, but can't drive the car.
