POV-Ray : Newsgroups : povray.general : realistic lighting I (fading) Server Time
3 Oct 2024 11:18:11 EDT (-0400)
  realistic lighting I (fading) (Message 1 to 3 of 3)
Subject: realistic lighting I (fading)
Date: 3 Dec 2005 06:10:01
Message: <web.43917b418a00281f7b4fb7150@news.povray.org>
the way povray handles the darkening of light_sources with distance (r)
isn`t very realistic unfortunately. in reality without(!) any attenuation,
intensity (I) follows I(r)= d^2/r^2, d being some normal distance where I=1
is assumed. for distances >> d "fade_power 2 fade_distance d " works pretty
well but for small distances intensity should rise much faster than
provided by the fade formula (see documentation).
My personal workaround was now to dramatically increase the light color (16
or so) and adjust a relatively short fade_distance by trial and error in a
anyone solved the problem yet?
maesju
Subject: Re: realistic lighting I (fading)
Date: 3 Dec 2005 06:34:56
Message: <439182e0$1@news.povray.org>
"maesju" <nomail@nomail> wrote in message
news:web.43917b418a00281f7b4fb7150@news.povray.org...
(r)
attenuation,
where I=1
pretty
color (16
in a
inconvenient...
actually, I often use light_sources with *extremely* high (all is
relative, I know) brightness, like this:
light_source {<10,10,10> rgb <.9,.95,1>*5000 fade_distance .02
fade_power 2}
I believe there is a set of macros that makes all this easier to do.
yep, found it, it's this: http://www.ignorancia.org/lightsys.php
cu!
Date: 3 Dec 2005 16:05:01
Message: <web.4392074d3395f0037b4fb7150@news.povray.org>
> fade_power 2}
> cu!
> #macro G(b,e)b+(e-b)*C/50#end#macro _(b,e,k,l)#local C=0;#while(C<50)
> sphere{G(b,e)+3*z.1pigment{rgb G(k,l)}finish{ambient 1}}#local C=C+1;
> #end#end _(y-x,y,x,x+y)_(y,-x-y,x+y,y)_(-x-y,-y,y,y+z)_(-y,y,y+z,x+y)
> _(0x+y.5+y/2x)_(0x-y.5+y/2x)            // ZK http://www.povplace.com
wow. that's exactly what i was looking for. It actually solves my next two
problems also.
I started writing a similar macro some time ago but dropped it again when i
read all this stuff about white point temperature. a.s.o.
another proof for my #1 coding rule:
don`'t think -- search.
Thanks a lot
Maesju
