I'm currently working on a scene which contains stacks of wooden word-blocks
(you know, those blocks that have letters engraved in them). To easily
produce these blocks I wrote a macro, that requires the letter and a color.
Now I was wondering how I could determine the center or size of the font
object so I can position it correctly. Because now with non-monospaced
fonts the letters are not correctly centered in front of the block.
thanks in advance!
min_extent() and max_extent()
Didn't think about that, but then I would have to declare the letter before
using it in the difference, i don't suppose there's a way to do it in the
text {..} block?
Correct.
>text {..} block?
Not in official POV, but there are h_align_center and v_align_center
keywords in MegaPOV.
Mike Williams
Gentleman of Leisure
Aren't they kind of obsolete? It isn't much more difficult to do the
same with the extents functions.
The extents functions were there first, but the MegaPOV text alignment
options keep getting reinvented. Over time MegaPOV has had "position 2"
and "align_center" syntax for text centring as well as the current
"h_align_center"/"v_align_center" syntax. I guess some people feel that
there's a need for it.
Mike Williams
> text {..} block?
Try this:
#local txtL=text { ttf FontName, "A",1,0 }
object { txtL
translate -(min_extent(txtL)+max_extent(txtL))/2
John
Are these special text functions still in MegaPOV 1.2.1, I didn't know.
Thanks for the advice!
They're in 1.2, I've not checked 1.2.1 but it's very unlikely that
functions would get deleted from a minor level change.
Mike Williams
